Slight smoke exhaust KTM EXC-R 450 2008
i recently bought a 450 2008 and have only done 3 hrs on it and have notice slight intermitent smoke from the exhaust. Is this normal when running in the bike or should i have someone take a look at it?
At 3 hrs it not completely broken in yet.
I'd call it normal but not after 10 hrs.
Also, check the oil fill level. They've been know to be a little high from KTM.
Mine was high from factory and it would dump smoke like a airshow performer if I landed while brakeing from a jump. Changed oil and it stopped smokeing.
i have now done 12 hrs on my exc-450 2008 and still when i rev it hard in neutral there is, from time to time, slight black smoke from the exhaust. I have had the dealer service my bike and was told that the black smoke is just fuel. Apparently when you rev it hard in neutral the fuel pumps pumps up extra fuel which isn't used and exits the exhaust as black smoke.
is this correct?
Also when I have just started my bike there is slight white smoke initially when reving it which goes away after one ot two revs. I know this smoke is oil but is it normal even if it has only been left standing for 6 hours or so?
the black smoke is carbon from a slightly rich jetting (desired), white smoke on startup is fairly normal, you'll find that is simply unburned fuel, when left sitting some fuel does always leak into the carby and strait into the engine, which is why on a two stroke you always turn the fuel off even if your only going to stop for 15 minutes otherwise they flood, blue smoke is your engine oil burning.
:thumbsup:
Waxy
Black puff is the accelerator pump doing its job!
With the stock crankcase and transmission vent lines routed into the carb you can get a bit of oil in there from time to time resulting in blue smoke. This is especially true after you lay the bike on its side, but can happen in normal riding as well. For some reason the trans vent will burp a bit of oil once in a while. You can just live with it or reroute the trans vent somewhere else.
  • Similar Content
    • By Jay_112
      Hey all,
      My name is Jay and i'm new to the forum community but not new to the sport. However I have reached my limit with my expertise and am hoping some of you may be of some help. Without further ado...
        I've stuck to a track most my life, I.E. Motocross, arena cross and outdoor national style tracks. I've made the difficult decision to leave to tracks to the young guns and ride more single track and trail riding up in the mountains. So i started by selling me Factory SLM racing 2012 Yz450F, yes i cried when he drove off with her. But i looked to greener pastures with hopes to have a KTM 500exc, Beta 500rr-s or a Husqvarna FE501. However, almost a year later and I still don't have a shiny new dirt magnet in my shop. I'm in the final deliberations and have narrowed it between KTM and BETA, with me leaning towards the BETA. This is where you come in.
      I would like to know the following.
      Is the Beta service intervals as daunting as the KTM's?
      Is the cost of parts between the two noticeable? And are the just as readily available?
      Those that have a 2017 of either bike, How are they holding up? Can I expect this bike to hold up like a 1985 XR250 (An almost impossible feat)?
      What are any major concerns about either bike?
      and finally what made you choose one or the other?
      Thank you for your efforts and advice. I appreciate it.
    • By jaworskime
      I have had this issue happen twice,  my efi and low fuel light are coming on, the bike will idle but soon as you give it gas it will sputter and die. The lights aren't on until you roll the throttle back.  Any ideas? Also the electric start won't work. Have to kick the bike to start,  and the computer doesn't come on when you turn the key and flip the switch to start,. Assuming it's a wiring  issue or fuel pump issue,  any help would be appreciated.
    • By motf
      quick, question - is it doable without removing the tank?
      thanks
    • By KeyKeeper
      I noticed my shock spring almost touching my exhaust on 06 525exc.  I pushed on the spring with my hand and the swing arm moved over 1/8"!
      I know that cant be right but looking at the schematic view of the bearing layout, wth holds the swing arm from moving side to side?  I see the bearings, sleeve, seals and some small cap type things that go on the end of the sleeves  (outer end) but what actually keep the swing arm from sliding side to side inside the bearings?  Looking at mine there appears to be some sort of spacer on the left side between the swing arm and frame beam but on the right, it just looks like the sleeve mates up to the frame?  Am I missing something on one side?  Got this bike in a trade.  So far the motor has been rebuilt at cannon racecraft in OKC, forks rebuilt, and its super clean and runs great other than it needed valve lash set.  So it seems odd that an important part like a swing arm spacer would be mia.  Any ideas?
