instrument cluster
My cluster is on the blink, it's only displaying partial. Has anyone had any issues, 07 TE450
Try disconnecting the battery and wait a few minutes then reconnect. That will reboot the system. Sometimes that helps.
I have gone through three of these speedo's on my 06 TE450 & all have been replaced under warranty. I did pull one off the bike to find that it rattled inside, I pulled it apart to find that a component had come off the circuit board, it looked like a resistor, but because it was under warranty I put it back together & took it in to the dealer & they said it was a common problem that the speedo's were failing. I have had a similar problem in electronic displays before & have had to reclip the LCD screen back into position & they came good, I dont know if this helps but good luck.
Damo. :thumbsup:
I had a problem with my instrument cluster on my 07 TE450. It had the same problem as you describe. I tried everything to get it working again. Finally I sent it back to the dealer (Heinins) and they replaced it right away. Great service form them.
Thanks for all your info. I got a hold of the dealer and they ordered me a new unit under warranty.
Thanks Again John
