timing chain
:thumbsup: i have what the dealers say is timing chain noise.my bike is an 02 klx300r with 2000 miles on it.it has always had consistent oil changes & mantaince .the bike is not abused,can any one say if the timing chain should have slope in it at only 2000 miles. also iam looking for a used pumper carb & cables for it:ride:
The cam chain has an automatic tensioner.
These things make noise. Some more than others but it shouldn't be worn out in 2k miles.
There was a feller on here that found the noise objectionable and made an adjustable tensioner. Claimed it made it quiet but I wonder if he made it too tight.
If you feel unsure about the chain being stretched? remove the auto-tensioner screw and see if it has tension before it contacts the threads? This is a good indicator that it is Not stretched!
After you remove the bolt from the tensioner, you can also remove the tensioner itself, and see how much 'travel' it has left before it hits the end.
Be sure to back the ratchet down before you re-insert it, and put the bolt that loads the spring in only after everything else is tightened up, otherwise you could over-tension the chain.
My wife's atv was noisy too on the timing chain and the trouble was that the auto binder spring was not setup tight enough from factory. I wind it another turn and I got rid of the problem. Spring was no tight enough to push the plastic slider on the chain. Could be that too? I never saw a klx binder so can't be sure it it could be possible too.
This is what i would do Just take it out and see if the sutomatic time chain tensioner is all the way out. not to hard to take out and look at. good luck.
  • Similar Content
    • By Apose
      Hello TT, I am currently going to replace the rear shock on my 2003 KLX125L (same thing as a DRZ125L with green plastics) and i would like to know if the KX100 shock bolts right in direct fit on the STOCK swing arm? i have searched around and haven't got a straight forward answer to my question for the stock swinrgarm and i know about the dr_drz thread for his DRZ but he's also using a KX swing arm. Just wanted to know if it's a direct fit besides removing upper chain roller or if there's any machining need done. Thank you.
    • By h204meplz
      Hi, I am looking to get my first dirt bike, female 5' 2" 125lbs.. I have experience riding quads, and a little experience just playing around on pit bikes and kids bikes.. Checking out the CRF 125, KLX 140, and TTR 125.. They all seem like a good place to start, especially being short and new to the sport. I think ill pick up riding pretty quick but want a bike thats gonna be a good starting point, not to big/tall/heavy, yet reliable and fun.. Ive looked at the CRF and KLX so far, I like the idea of a little extra power with the klx.. but like the kick start option of the CRF and in general kinda like Hondas.. Another friend recommended the TTR so just want opinions/comparisons and input from anyone willing, thanks so much!
    • By bhcolvin
      I have a 1999 KLX300R which I bought this past April (2017). I only ever ride it on the weekends for no more than an hour (time constraints). Since I bough it, it has always ran hot. The oversized aftermarket pipe it has constantly heats and burns my leg, just from those hour rides. I've dropped it twice and both times the coolant boiled afterward, but it doesn't boil when I just riding it normally. Just this past weekend (late July), I went riding with some friends and put some hard hours on it. As I was coming in for a break I pulled in the clutch and the engine immediately stopped and locked up. I got off and tried to kick it over but it wouldn't budge. I let it cool down then rolled it back and forth in 6th gear to free it up. It starts and runs smoothly now, but there sounds and feels like there is something rattling around in the top of the cylinder.
      What should I do? Can and should I try to swap another engine into it? What could the problem be? broken piston ring? broken valve/shim?
    • By bhcolvin
