tubess spoked wheels (SM)
I have seen the big BMW adventure bikes sport tubeless spoked wheels, the spokes go towards the side of the rim rather than the center, so the inside remains sealed.
What options are there for 17" SM wheels in that layout ? No bling necessary and preferrably affordable. I would like to lose the tubes, it seems like such an antiquated design with has no real advantages.
How much money have you got?
Your Choices:
1) BMW style spoked rims, very expensive
2) 'Mag" wheels, very expensive
3) 'Tubeless' conversion kits, cheap but not perfect
4) Do it yourself with silicone, tape and luck, very cheap and not perfect
A few guys have done the last three. Me? I'd only consider the top two. If you tighten your spokes, you run the risk of breaking the seal with #'s 3 and 4.
Alpina sells tubeless spoked wheels but I have not seen any DRZ specific set from them.
I have also seen a kit used to retrofit normal spoked wheels but its use was competition only not street (liability probably).
Your Choices:
I work in the HVAC industry. Years ago we were using a red duct sealer made by DuroDyne that was seemingly bomb proof. It would seal a gas tank and hold. We havent used it in a long time due to cost, fume and cleanup issues. We use water based now. Right now I am working on a 35yr. old hospital retrofit and its a bugger to get off. I'd find me some of that stuff for sealing spokes. Its called S-2
The problem with many sealers on the spoke heads is what happens when you tighten the spokes.
How much are the Alpinas, and where to find them ? Can't find them on motostrano outside of a few articles referring to nonexistent pages.
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
