CR80 28mm? Keihin on bbr 120 manifold?
I have a 90's CR80 carb that was given to me and I was wondering about using it on my BBR 120 XR100 project bike. I am assuming that I may need the same intake adapter as used with the mikuni VM26? Can someone please tell me if an intake is available with the correct angle that will hose clamp to the non-flanged smaller style carbs and bolt to a stock XR100 head? Any help is greatly appreciated!! :thumbsup:
I had a 2 stroke carb on my 120 for a while and after changing every jet, needle, slide etc I went back to a 200X carb. I couldn't get it jetted properly. I think minifigphil had success with a yz 80 carb, but he may be more patient than me:)
But isnt the VM26 basically the same 2 stroke type carb that people like to run on a modified 100?
Yes, I was using the VM26 and it was just more finicky to get jetted properly than a 200X carb. You have to change every piece in it to get it to work.
