Scotts front mount
Anybody ever mounted a scotts out front? got any pics? thx, OFG
I've seen mounts like that for CRFs, but never for a Husky. Would be interested in seeing it as well.
The issue I have with these mounts is the frame bracket and linkage. I ran a WER on a bike and the frame bracket kept working loose. Additionally there was so much play in the linkage after a short while there was a good range of movement before the damper did anything. My buddy has one on a KTM200 (WER) and is always having issues with it. I like the mounting but not the issues involved with it.
I have a WER I hate it! It has not been right since day one. I bought it new in the sealed package. It has always had more damoing one way than the other. I sent it in, it came back the same way. I took it apart and done some work inside that really helped it. I run it almost all the way hard. I wish it had high speed damping like the scotts. I got a scotts used, I am gonna fab a bracket and stuff. My weld on tab for the WER should work ok I hope. I will start on it soon. I have got too many things started right now!!!!!!!!! OFG
Oh. I forgot to mention, many of the lower front mounts designs damp more in one direction than the other. It's not the damper but the geometry. Look at the travel of the arm when you sweep it from lock to lock. I bet it is not linear. Your trying to make a parallelogram work through an arc and you wind up with rising rate on side and falling rate on the other.
all the that said i have a wer is the best thing i have done to the te no probs with dampening just confidence and inspiring
And for the record I am in no way bashing WER I'm simply discussing the challenges of this mounting solution.
I forgot to mention, I mounted it in the vise, on the bench. It was harder one way than the other, when it was not even on the bike. I wish I could afford the new motosportz damper, that looks like the way to go! OFG
  • Similar Content
    • By 305hestbeck
      So I just sold my bike 2017 TC250 with only 17 hours on it. When it left it was in brand new condition. But 2 days later the engine cases were being split.
      Turns out the Idler gear had snapped off during the new owner’s first ride. Of course I am not paying for the fix as one it is clearly a manufacturing defect. I told him If needed I would help by me claiming it as warranty issue.
      Anyways I did some research and discovered that the KTM/Husky expected a 6x12 to hold the idler gear sys together on 2017.
      Well this seems to be an issue and KTM did fix it for the 2018 models. They actually updated the whole Idler gear sys, but if you still have a 2017 2 stroke the fix before it happens which it could on the first kick would be to replace the bolt with a 6x20.
      You will have to tap the hole for more treads. Actually the 2018 engine case was also updated for this and that’s all they did.
      I own a 2018 TX300 now. One reason why I looked into it.
      Just thought I would share.
    • By Tranos07
      Greetings to everyone. After a lot of searching I finally decided to join this forum in order to finally find a solution to my problem. Here's my story. Bought in a hurry an sm610 2005 (cylinder with the small tensioner) which wouldn't start cold. Only if I connected it to a car battery would it start but not always and not easy. Got a new 14amp battery and nothing. Spark plugs,starting spray etc nothing worked out. If the engine was cold it would start in an instant very very easily. Took it to a mechanic he told me that it had no compression so he grinded the valves. When I got there to take it back he told me that my pick up coil was in bad condition and needed to be replaced in order to start cold. Of course nothing changed after the valve job and after 5 hours of riding(not constant) my new head gasket blew and when I took it apart I found a crack in the water passage on my head right next to the blown up spot on my gasket. I don't know if it was already cracked or if it cracked after gasket blew all I know is that it was tightened properly as I was in front when this happened. I'm just trying to figure out why i can't get it to start cold. All answers are welcome. I had the head fixed and I'm ready to reassemble the engine. Could the pick up coil actually be responsible for this? Another thing I noticed. My tensioner had an apostate welded up to it so i needed a new cam chain as well as a new tensioner. I have these. Could the ruffled chain be in charge? The engine was perfect when hot starting and working like a charm. Please someone help as I'm ready to take the damned thing and throw it into the ocean.
      PS is the pick up coil from an lc4 engine compatible?
    • By birdland101
      Restored 1974 honda xr75 original motor and frame podercoated frame runs, looks, shifts, stops good. top end rebuild many new parts most all honda. email birdland101@hotmail.com.
    • By Jawehangwe
      2017 Husqvarna TX, TE, FE, 125, 250, 300, 350, 450, 501
      Greatly reduced arm pump and fatigue
      Increase rear wheel traction while standing under acceleration
      Create a seat bounce effect when jumping standing up
      Shave seconds off your lap times
      Light weight and adjustable
      Easy to install
    • By MotoXRacer_19
      As I was inspecting my new-to-me bike that I just purchased, I noticed there is a grove on the back side of my front brake rotor that goes completely around it, and you can feel it with your finger nail. I have noticed some poor performance, but I figured it was because of the new pads that the previous owner installed just before I bought it hadn't seated yet. However, I've ridden a couple times and it doesn't seem to get much better, if any better at all. Is that enough to explain why when I pull in the brake as hard as I can, it only slows me down a little, instead of going into a stoppie and over the bars (as I wish it would)?
      Should I look into buying a brand new rotor?
      I have no pictures of it, I'll try to post some when I can.
