Dry Moly chain lube
A few years ago , there was alot of interest in Dry moly as a chain lube. I think every rider has tried it at one time or another , what was your assessment of using a dry lubricant on a motorcycle chain?
Dry on a chain is better than wet. Issue is getting it to stick and not get flung off. Many wet ones are actually dry based in a quickly evaporating carrier solvent. you return from a ride, lube the chain and let it sit over night. The chain lube stays on the chain. The carrier helps it flow over the rollers.
I use a teflon spray that goes on wet and then dries. It doesnt really fling off. The small amount of spatter I get just wipes clean. Its called Tri Flow and I get it at my local hardware store.
