Moto LED - Is this right or a problem?
Added Moto LED 602 blinkers to front & back, together with Edge II tail light. Also installed a UFO 55/60w headlight. With the headlight connected (lit) and bike running the blinkers blink so quickly they are almost continuously lit. With the headlight disconnected, the blinkers work much better. They do flash quicker than a stock blinker (which other posts have indicated is expected), and are no where near continuously lit. With the key on and bike not running, the blinkers are dimly lit and do not flash. Tail light and brake light are working fine, as does everything else.
This is last step in my moving an E to an S frame, using S harness and controls. So I don't have any experience with this on bike in stock form.
Will the resistor addition take care of this or there some other issue here? Thanks!
Resistors or a relay should bring the blink rate back to a normal level.
Replace the relay with an electronic unit that is not load sensitive or add resistors to increase the load back to near where it was with the stock signals.
Thanks guys. Added 10 ohm 10W resistors. Took it from disfunctional to a blink that is faster than stock but acceptable.
  • Similar Content
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
    • By Markl5557
      So I’m reading these horror stories of the stock vacume operated petcocks failing and letting gas into the oil .... how many of you guys switched over and is it worth it to switch to manual ?
    • By Markl5557
      Hey guys . I feel like I post here way to much lol
      anyway after having my bike kn it’s side overnight to fix a cracked stator cover .... I come to find out that I also accidentally left the pet cock in the prime position .... constant gas flow to carb ... now my oil smells strongly of gas ... my question is ... was it the bike being on its side that made the gas get into the oil or the prime position on petcock that made this happen ? Or both ? I didn’t ride it much at all after discovering... I assume. I should drain the oil obviously but any other suggestions ? Always appreciated -mark
    • By Praneeth143
      Hello guys , I have a suzuki drz400sm which is a 2009 model recently I purchased a rear sprocket which was a JT 41T , but I found that it did not fit to the rear sprocket hub of the bike and my drz has got the EXCEL TAKASAGO rims in it . How can I find one that fits and what sprocket brands and where can I buy it . I have attached pics of the current setup , please help me
