Mikuni Pumper - OK, I'm sold
I finally got to go out and ride for a day with my new pumper carb. It is better than my first impression. Here's the thread for that:
http://www.thumpertalk.com/forum/showthread.php?t=593672
It was really easy to pull up wheelies over any obstacles, a lot quicker to respond to the throttle with the pumper. I had been trying to tune out some popping on decel and went with larger jetting 132.5/17.5. That proved to be too rich. It was loading up pretty bad on downhill sections and was really hard to start hot.
At lunch, I jetted back to 130/15 and it was much better. But it may still be just a tad rich. I may need to do some more fine tuning on the fuel screw.
With the 17.5 and the 15 pilot, I was still getting constant popping coming down hill off the throttle. I just can't seem to tune that out. My stock carb is about as perfect as I can get it, near instant throttle response, great mid and top end, and no popping coming down hill. Starting iwith the stocker is quite the drill though.
Anyway, I'm going to be keeping the pumper, I really like it and the super quick wheelies it pulls up. Mid and top end seem the same as the stock carb. But with a 2 kick cold starting of the Mikuni, it is definitely worth it.
The Mikuni Pumper was the best mod I ever made to my XR. Some minor popping on decel is perfectly normal and to be expected if you have an aftermarket exhaust on the bike. Your fuel screw should be about 2 and 1/2 turns out. Make sure you have the little phillips head screw with the spring on it (on the pumper actuator arm) turned all the way in until the spring is neatly compressed. I don't have my XR any longer so the details are a little sketchy, but I do have a few pics of the pumper setup if you need them.
Trailryder42 should be able to chime in with some details...
  • Similar Content
    • By libsead
      Guy's,  I have an 1997 Honda XR400R and I need to do the front forks.  I'm a big guy 6'4" 375lbs.  So far I haven't been able to find a setup for a big guy. Any suggestions besides losing a lot of weight. :-)
    • By Scat Adams
      OEM Rear fender from an XR400. Fender includes Baja Design tail light as well.
      $20 plus shipping, located in San Diego.
    • By Alex John Blanch
      Went riding on Christmas Eve  everything was working fine went through some mud and slipped dropped my bike tried to kick start it and the kick start went limp pushed it back up got compression again  kicked it over a bunch of times started to run again  rode it for the rest of the ride with no problems then on the way back on the road I gave it fill throttle  and it died hasn't started  since and now has little compression. Replaced the spark plug and changed the oil and filter and adjusted the valves but still very little Compression and won't start.
      Any ideas??  Would greatly appreciate
    • By Ricky Bobby 21074
      I have a 1986 xr250r, I'm interested in converting the rear drum brake wheel assembly to a rear disc brake system. Has anyone done this, and can you tell me what application parts will get the job done. thanks
