CRAP!!! Lost the needle spring!!!
:thumbsup::eek::D:ride:
Figured I was capable of doing the rejet myself, heard it wasn't too hard. Got the suitable kit from James Dean and away I went.
Everything was going well until the needle spring popped out. I looked everywhere for it, but it's so small.
Is this spring available at the dealer, does someone know of a suitable replacement?
God I fell like a tool.
:lol::ride: :ride: :ride:
Did it fly off somewhere? Did you look down in the cavity where the needle retainer plug is? My spring stuck to the plug when I pulled it out.
If you cannot find it, it is a standard OEM part.
Uhh, which carb?? I'm guessing a Mikuni?
you will find it when you buy a new one .... thats what usually happens .
I looked, but no luck.
It shot the retainer plug a good 4 or 5 feet. Another learning experience.
William1, any idea on the part number? No worries if you don't. Have to waite til Monday and check with the local dealer.
Thanks for the reply.
Yes.
It's a 2004 KLX400sr.
Anybody who used the DJ kit should have a spare.
Quick fix, spring from a biro, or a short peice of fuel resistant hose cut to length.
Neil. :thumbsup::eek::D
Try laying the bike on the side... I lost a screw and could not find it even after taking parts off....turned it on the side and shook it... it mysteriously appeared. From where I have no idea..
Thanks! If I have to wait for a replacement I will give this a try.
My JD kit did not have a spare. Should it of had one?
Pn 13268-48700
Your talking about the small needle spring that rests under the needle cap... Yes?
part number 5
When I have dropped similar items I get my big magnet out and find it that way :thumbsup:
db
a shortened spring from a inkpen is almost a perfect fit
:ride::lol::ride:
Well, being the impatient person I am and knowing that I was looking at a possible week long wait for a new spring, I took some advice from Neil and took a spring from a pen. Cut it in half and installed it. The needle's tension felt very similar to the stock, so I was feeling good about it. Funny thing is I lost that little O ring as well.:thumbsup::eek::D
Anyways, fabbed up a replacement, put everything back together and turned her over. and can you believe it, she fired up immediately.:ride: :ride: :cry:
She feels a little boggy. I have done the 3x3 airbox but still need to "uncork" the stock pipe, and play around with the settings.
Just so everyone knows, I do intend to order in the replacement spring and O ring, but this at least got me back on the road.
Thanks to all for your replies.
  • Similar Content
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
    • By Markl5557
      So I’m reading these horror stories of the stock vacume operated petcocks failing and letting gas into the oil .... how many of you guys switched over and is it worth it to switch to manual ?
    • By Markl5557
      Hey guys . I feel like I post here way to much lol
      anyway after having my bike kn it’s side overnight to fix a cracked stator cover .... I come to find out that I also accidentally left the pet cock in the prime position .... constant gas flow to carb ... now my oil smells strongly of gas ... my question is ... was it the bike being on its side that made the gas get into the oil or the prime position on petcock that made this happen ? Or both ? I didn’t ride it much at all after discovering... I assume. I should drain the oil obviously but any other suggestions ? Always appreciated -mark
    • By Praneeth143
      Hello guys , I have a suzuki drz400sm which is a 2009 model recently I purchased a rear sprocket which was a JT 41T , but I found that it did not fit to the rear sprocket hub of the bike and my drz has got the EXCEL TAKASAGO rims in it . How can I find one that fits and what sprocket brands and where can I buy it . I have attached pics of the current setup , please help me
    • By Surfman1
      Hello all, first time poster. Just bought this bike a few days ago it’s an 08 drz 400sm and am starting to notice it has a strange backfire at idle. I understand a little bit at decel might be normal, but at idle too?  It appears to have been jetted already, judging by the fact it has a jd jetting sticker on the bike itself. I know that it’s not an exact indicator it has but it could be. Has an FMF exhaust, it looks like a full system rather then a slip on but not entirely sure. A buddy recommended I mess with the air and fuel screw, haven’t done that yet. Just wanted to see if there was any other tips I should try.
