Anyone tried Engine Ice?
Getting a head-start on summer by changing the coolant, was wondering if anyone has used Cycle Logic engine ice coolant, and if it was any better than the regular stuff....thanks in advance gents!
I have used it and it works fine.
Just make sure if you go to the store to buy a tester you get one for propylene glycol and not ethylene glycol.
.......wha? Don't understand, please elaborate!!
Have used for years in 2-stroke bikes for hare scrambles with good results. In the gnarly stuff the added boil over protection does seem to work. At muddy national event last year one of the bikes had boiled half the engine ice out but what was left kept the bike going without any adverse affect. For normal use I believe regular coolant works fine, but if you need the little extra margin this gives you its worth the price.
I found a deal on engine ice several years ago and bought a bunch. It keeps my built bike cool even with putting around with the wife, not to mention when caked with mud.
I have used it for years in 2 and 4 strokes. I think it works better than regular coolant.
ive had good luck with it in my raptor
and none of my friends tht use it have any problems
it deff works better
Regular green coolant is toxic and ethylene glycol based.
Engine Ice is non-toxic and propylene glycol based.
If you buy a regular coolant checker it will not give you proper readings. You must get a propylene glycol one. They are only like $5 at NAPA.
i used it in my yzf400 when i raced cc and hs and it made a difference
Just did it and call my nuts it felt that the bike was cooler....
Ive used Engine Ice in four strokes in 100 plus weather slow, tight trails with no problems. As far as being better than regular coolants? depends what is regular I guess. As mentioned Engine Ice is a propylene glycol. I swithced to using ethylene glycol like Honda HP and Maxima because it is supposed to have a higher boiling point as well as being thinner and easier to circulate.
i used the pre-mixed redline with watter wetter.... workes good and makes it legal for the track... same idea as the engine ice stuff
