Rekluse settings and manual??? vs. jetting
Ok so I am not pleased with my low rpm performance on my 2004 yz250 2 smoke. My buddy has an '06 and we are running the same pre-mix and the same jetting exactly, we have the same pipe, just diffferent silencers, and I have a rekluse, ho does not. Out on the trails today, and we switched bikes, he was running awesome, my low end felt like it hesitated, and was gutless, but when in the mid to full throttle range it felt good. I was originally thinking of going leaner on the pilot cuz i had a little spooge, but his jetting was perfect. Now I think it might be that the Rekluse is engaging at too high of an rpm or that some other adjustment in the rekluse is off.
Does anyone know where I can download a manual, and what are the different adjustments inside there???? What should I try thanks?
ok thanks, got the manual. Does any have experience with setting the rekluse, do you need to buy the different springs? How many adjustments are there adn what do they all do?
With the YZ I assume you are running the perch adjuster. There are two springs a light one for offroad use and a heavier one for MX. Go back to the Rekluse sight and look up the perch adjuster instructions. The perch adjuster can be adjusted as well.
sorry it's the Pro model, so I still have a clutch lever. I know there is a hard and soft spring and you can change if it engages at low medium or high rpm. Anyone have experience with this?
Use the black spring with 27 balls. Make sure your installed gap isn't too wide.
Rekluse suggests Rotella T, I use Ford type F ATF.
The clutch will lock up hard and not be a cause of sluggish performance. Get you jetting squared away and your bike will be OK. Remember, the auto clutch isn't an auto tranny. Don't lug your engine which causes accelerated clutch wear.
I attached the tuning guide for the YZ.
198-870-Tuning-Chart-YZ250-2stroke-051707.pdf
ok thanks, I'm going to move my needle up 1 positiona nd see if that helps.
So I'm running 80 torco synthetic right now, should I change to the non syntheitic? Do you think that makes a difference with the rekluse?
  • Similar Content
    • By fudgypup
      Garrett Poucher and Skyler Howes of Garrett Offroad Racing are headed to Dakar!  These US privateers are headed there for their first times but Skyler is fresh off a victory at last week's Baja Rally, won the Sonora Rally in March and this team placed third in the Baja 1000.
      They have a fundraising link set up and could use your help.
      I raced with Garrett at Baja Rally last year and then both of them at Sonora and was honored to pit with them as well.  They're both super guys and work their assess off.  I think they both have good chances of not only finishing the 11 days of Dakar but placing well.
      They're doing some rally training events this Sat, Oct 20 in Santa Clarita, CA and then another Oct 28th in St. George Utah so if you've ever considered learning rally raid navigation, this is your chance!  It's a lot of fun too.  More info on that at the link.
    • By Big64N
      Good condition with a long list of high end upgrade parts.
      Rekluse EXP 3.0 with cover and slave
      EVO- Ellensburg suspension tuning for 6' 200# expert rider
      Fork bleeders
      Trail-tech map switch
      Moose 1-1/8 flex bar
      CYCRA probend bar guards
      SXS skid plate with linkage plate
      Clutch and water pump guards
      Frame guards
      Fastway Evolution III pegs
      SRT Pro Armor radiator and rear rotor guards
      Acerbic Front rotor guard
      TM designs chain guides
      DID race chain
      Renthal sprockets
      Gripper seat
      FMF F-bomb header
      Dirt Tricks timing chain tensioner
      Pro Wheel, wheels
      Tubliss front and rear
      New top end and valve adjustment 60 hours old
      Many more aftermarket parts as well as spare parts and service manuals included in the sale.  Willing to include 4 sets of tires with 80% tread left for full price.
      Great bike with plenty of life left and set up for anything from single track woods to wide open dessert.
      Can hang with any of the 450's but is much easier to handle in the tight woods.
      Priced to sell at $6000.00
      Willing to consider reasonable offers but no trades or carry.
    • By filterx
      34 Days and what ever in Beautiful Chile
      http://www.fim-isde.com/home/
    • By Project57
      So if I can’t buy a used bike from out state looking for anyone that has or knows of a low mileage California 2017 / 2018 Beta 500 RRS?
      Thanks in advance!
    • By Project57
      Looking to buy a used Beta 2017 500 RRS from outside California.  Can I plate (Register with CA DMV) the bike in CA?  If so what is the best way?  Don't have the money to put down for a new bike from a Dealer in CA.  Any help or sugguestions would be appreciated.  Thanks in advance.
