Free Service Manuals on line
thanks dude
:thumbsup: thanks for the link
Awsome link.
Thanks~ :thumbsup:
The link does not work
it does not work!!!!
Sorry guys… I don’t know what happened? Seemed to be working fine a couple of days ago when I originally posted. Maybe the website received too many hits???? :thumbsup:
noooo!
does anyone have an 08 kx250f manual?
or even an 07/06, they will probably be the same.
ty ;D
That should work for an 08 kx250f also?
like most things in there should be the same, correct?
very,very close......
  • Similar Content
    • By TPA-MX
      Hi guys,
      I have a 2014 KX250f that has a super small hairline, I mean super small hairline crack just under the main engine plug hold on the ignition cover.  You cant really see it, but it "slowly" will leak oil out if let set long enough.
      I would like to permanently fix it.  Right now, I just used some clear silicone on the outside and it stoped the leaking.  However, looking to sell the bike and I want more of a permanent fix.  The 3 options I see are:
      Replace just the ignition cover Replace the entire Stator/ignition cover Use some jb weld on the outside, sand down and paint My questions are:
      On #1, how hard would it be to use my existing stator / magneto items and install in a new cover? On #3, can JB Weld be grinded/sanded down to a smooth finish?  If so, what is the best material to use?  Regular wet/dry sandpaper?  If I go this route, I would want it to look decent, then paint the entire cover black with hi-temp black paint.   What would you recommend?  Am I missing any other alternatives?   Thanks!
    • By rollin30
      I need a subframe for a kx250f and an exhaust system too
    • By rollin30
    • By Andrew Oberther
      I picked up an 09 kx250f as a winter project and it had a chewed up head, and is unrepairable. I was online and found a 2011 kx250f head and was wondering if it would fit. Thanks.
    • By Temetti
      Nasty collarbone crash.
