yz125 or yz250?? info about me..
hey guys, sorry if im not allowed to post here..! :thumbsup:
i just have a question for you, im 16, 174cm(5foot8inch?) weigh about 140pounds or more..
i've been riding since i was 10(6 yrs all up), only only smaller old bikes, i rode my brothers xmoto250 the other day(chinese bike), and i handled it pretty well.
i'll be riding through forestry, which is mud, some hills, alot of long straight flats and just stuff like that, 1 day i will probably consider doing MX on this bike i'll be getting, and il be keeping it for a few years.
now i've only got about $4000AUD which is like $3700USD i think??
NOW MY QUESTION IS....should i get a yz125 or yz250 with the money i've got..i may be able to up it by anothr $500 ..it depends!
thanks for all your kind help, sorry if im in wrong section.
sounds like you could get an awesome '06 YZ125 or YZ250 for that money, mate! :thumbsup::eek:
although i'm not preempting on judging your riding skills, given your age and weight, i might be inclined to recommend you the 125. yet, if you feel or your that type of person who simply likes to challenge the status quo (or common beliefs) then shoot for the 250 :D
remember i will be keeping this bike for a few years..so yeah??
250 all the way...im 15 and ride a 525...honestly it may seem pretty fast off the git go but you will be happy you didnt mess around with the 125....125's are good for tracks and thats it IMO i know some on here use them for racing offroad..but your not so why be on the pipe all the time and be going through top ends...get the 250 nuff said
thanks bro, how tall are you?? and whats your weight?
6'2" 180..im a big guy..my bud is 5'8" 140 and he rides a honda crf450r hes 15 also. he seems about the same size as you so a more adequate comparison
hmm ok then, well im growing pretty fast..how long you been riding for though? thanks
uhm i rode for maybe a year when i was 8 or so on a little ttr 90...got back into it when i turned 14 and got a 250f rode that for almost 2 years then got the 525...after the first couple of month on the 250 more power was needed..or wanted however you put it...if your a decent rider the honeymoon stage of a smaller bike will wear off rather quickly and leave you begging for more power
ok thanks bro.
well if you're trail riding..honestly..go for the 250. if you get the 125 you'll have to have it wide open all the time or you'll foul the plug. the 250 is a very versatile bike..it will putt around all you want it too and still not foul the plug. I haven't riden(sp?) in about 10 years and i just bought my 250..i used to ride an 80..and i love it! granted...if you aren't careful..you'll eat it..(i did today..pretty bad actually...went off the trail and went flying off the bike..bike flipped...i slid and rolled...thorns..ouch. gotta give the bike credit though...started right up first kick after that.) anyway..rambling, you'll be happy with the 250..especially if you plan on going mx. my .02
thanks :thumbsup:
If you can try and ride both before deciding.
But if your a newer rider, I'd get a '05 or up 125.
I had a '05 RM-Z450 before my current '06 YZ-125 and I can do everything with my 125 that I did with my 450.
I also just rode a friends '08 YZ-250 and didn't like it, but I'm a wuss:busted:
BTW I'm 5'5, 155 lbs.
Good Luck:thumbsup:
  • Similar Content
    • By MathiasJK
      Hi guys, I'm new here and bought a have 2001 a month ago and the engine is almost down in pieces, need the flywheel puller that's ordered and the parts needed for the rebound of the engine. I'm also ordering Haynes YZ manual as I think it will be a good buy for me.
      Anyway, the VIN strarts with CE08CE I think... on the back of my cylinder there where some mechanic had written with a marker pen -01 125. It seems like there have been a major failure before, as the head has small dents in it, and the cases are clearly not the same as the one with the VIN is much much smoother in the inlet and crank case.
      Engine VIN is E111E I think, or something very similar to that.
      It has a white Airbox and floating front brake, I've read on other threads here that that was a new thing for -01, is it?
      Fast help would be much appreciated so that I can order parts as soon as possible.
      BTW, here a rebuild with wiseco crank, all seals, new main bearings, new ring and all new  gaskets cost about 500$. Just the crank at Yamaha was 1,200$ at the local Yamaha centre so you all should count yourself as very lucky!
      Thanks for help! I'll post other threads soon as I'm at the beginning is going to post the cases for a smoother flow and have complete HGS system. I really would love to have a 144 but I guess that will cost me insane money as everything is more expensive here, and I also guess sending head n cylinder to the U.S. would cost way to much too... So I'll, be doing what I can on my own and that's the cases for better flow and matchporting it to the cylinder.
      I much appreciate any help! Thanks!
    • By faizakhtar125
      I've heard if you put VForce Reeds, properly jet your carb and clean the carb, change the exhaust pipe, clean the airbox and put a new air filter, and properly fix the shocks to match your weight, you can gain a ton of power?
    • By Allooushh
      Please help! I recently bought a Yz250f and have not been able to start it, it Has spark, but there are many issues with the carby which I wanna rule out before I leap into a rebuild, ( I want to avoid a rebuild if possible as I’m low on cash). The carby at the moment is a complete mess so the usual steps to fixing it might not work. So here’s the deal with the carb:
      - It’s leaking fuel from overflow ( really fast! ) and when I mean really fast, I mean it emptied my fuel tank in 2 mins.
      - It has a slow leak coming from somewhere under the float bowl
      - the air fuel screw is not adjusted correctly
      - I don’t know if the electrics work on it either
      - I don’t even know if it’s shooting fuel into the cylinder or not, as after kicking it a couple times and it’s not starting I remove the spark plug and it’s still dry. ( I tried putting fuel directly into cylinder from the spark plug hole but the bike still wouldn’t start)
      okay so I know it’s a lot but I’m not expecting anyone to answer every single question themselves. If each person could tackle whatever problem they know it would help heaps. Also just want to know what Order to fix things in as I can’t do air fuel until the bike is running and it won’t run unless I stop the leaking and get it to spray fuel into the cylinder. And buying a new carby is not an option ( I’ve got $40 to my name atm). Please help guys thanks.
