No compression
Was hosing down some dirt off my bike yesterday night. It started up fine after tat to park my bike
But this morning was trying to kick start it, there was no compression at all.
any idea what could be my prblm? was suggested that was faulty sparkplug. But is it possible tat a plug could foul overnight?
btw there's light coming from my headlight when i kickstart. and oh. i'm riding a 97 xr4
thank you
Maybe some water got into the intake somehow. A plug will not foul by itself overnight. I'd pull the plug and squirt a little oil in the hole and kick over to work it into the rings. Then try again to start it.
Might be a long shot, but disconect your decomp cable from the motor, i removed mine and never looked back.
Might be a long shot, but disconnect your decompression cable from the motor, i removed mine and never looked back.
Not sure how a spark plug would affect compression unless it was loose or out.
thank you martinfan30 it worked~! thou i took me quite some kicking to get it running. changed my spark plug @ the same time (and boy its black)
Bubbagums, confused myself thou...but it WORKED!
EMMS xr250, i've noticed the unless'ness off the decomp as well. only once in a while when i cant get tat kickstarter down. since you put it that way will remove it.
thankz for the input guys...appriciate it~!
  • Similar Content
    • By libsead
      Guy's,  I have an 1997 Honda XR400R and I need to do the front forks.  I'm a big guy 6'4" 375lbs.  So far I haven't been able to find a setup for a big guy. Any suggestions besides losing a lot of weight. :-)
    • By Scat Adams
      OEM Rear fender from an XR400. Fender includes Baja Design tail light as well.
      $20 plus shipping, located in San Diego.
    • By Alex John Blanch
      Went riding on Christmas Eve  everything was working fine went through some mud and slipped dropped my bike tried to kick start it and the kick start went limp pushed it back up got compression again  kicked it over a bunch of times started to run again  rode it for the rest of the ride with no problems then on the way back on the road I gave it fill throttle  and it died hasn't started  since and now has little compression. Replaced the spark plug and changed the oil and filter and adjusted the valves but still very little Compression and won't start.
      Any ideas??  Would greatly appreciate
    • By Ricky Bobby 21074
      I have a 1986 xr250r, I'm interested in converting the rear drum brake wheel assembly to a rear disc brake system. Has anyone done this, and can you tell me what application parts will get the job done. thanks
