trans oil questions 72 ts400
ok when i put oil in at the oil fill on the case does it also add oil to trans?
im a bit confused about it still as i have 3 separate drain plugs 2 are for oil 1 is for when you flood the motor
i sealed the hole in my trans w jb weld and i want to fill the trans with oil to see if it helps my shifting problem....if it doesnt the motors comimg off and stripped
and spare motor installed :thumbsup: its suck a pain wrestling with the motor to get it in and out
