Dirty drz
Will a pressure cleaner hurt seals and gaskets on my drz?:thumbsup:
Pete
it wont hurt anything unless you spray it super close and hold it for a while. try to avoid spraying the carb as much as you can.:thumbsup:
Good going to buy one in the next few weeks .Sick of bucket and sponge thanks
I use a small electric one. Only 1300 psi. adjust the wand to a fan spray and you should be fine.
Thats about what i was looking at .Only 100 aussie dollars:thumbsup:
We've one of those crap Super Cheap Auto ("Super Works" brand) ones, and it's lasted well for 2 or so years, and does a good job of cleaning. It was only like $70 aussie dollars anyway, so for $100, you'll get a better one. The only downside of our one is it doesn't have a soap attachment, and it can only use water from a hose, and not a bucket during water restrictions like the higher priced ones. Anything you buy will be better than a sponge.
I have a really powerful one and I've never had any trouble with it, like everyones been saying don't get to close and don't run the paint stripper setting or something. My brother did blow all the stickers off his left numberplate in about 1 second with it, so it is possible if your not careful.
As long as you stay away from spraying anything sealed (chain, elec connections, oil or grease seals, any place that has grease behind it ie steering head, swing arm) you will be fine. High pressure water can easily be pushed past those seals/ connections .. corrosion or rust will quickly follow.
All that said,, I’ve been pressure washing dirt bikes for as long as I can remember, once I learned the above,, I’ve not had any issues.
I would sure be careful around wheel bearings, headsets and the carb. I have a 5 hp cleaner and never use it on my bikes. I think it would work well for getting caked mud off from under the bike and under the bike, but other than that, I think good old soap and water do a better job.
Thanks to all
Pete
Pete
It's best to just use a hose and a brush.... you will have to use a brush anyway. :eek:
  • Similar Content
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
    • By Markl5557
      So I’m reading these horror stories of the stock vacume operated petcocks failing and letting gas into the oil .... how many of you guys switched over and is it worth it to switch to manual ?
    • By Markl5557
      Hey guys . I feel like I post here way to much lol
      anyway after having my bike kn it’s side overnight to fix a cracked stator cover .... I come to find out that I also accidentally left the pet cock in the prime position .... constant gas flow to carb ... now my oil smells strongly of gas ... my question is ... was it the bike being on its side that made the gas get into the oil or the prime position on petcock that made this happen ? Or both ? I didn’t ride it much at all after discovering... I assume. I should drain the oil obviously but any other suggestions ? Always appreciated -mark
    • By Praneeth143
      Hello guys , I have a suzuki drz400sm which is a 2009 model recently I purchased a rear sprocket which was a JT 41T , but I found that it did not fit to the rear sprocket hub of the bike and my drz has got the EXCEL TAKASAGO rims in it . How can I find one that fits and what sprocket brands and where can I buy it . I have attached pics of the current setup , please help me
