2002 YZ250F Jetting
I am installing a Big Gun Quiet pipe and Dynojet Stage 1 kit on my '02 YZ250F Does anyone have recommendations on jetting, and/or tips? I am located in central NJ, so I am not too much above sea level.
Thanks...Tom
i recomend not using the dynojet kit.
I live in new york and the elevation is about the same. I followed the dynojet instructions that it comes with and it ran good and i got more power. I just recently changed mine though because i put in the cam mod on my yfz 450.
and eddie why would you not recommend dynojet.
what do you recomend??? because i was looking for a jet kit. i have the same bike except 2003. and i was looking at JD, do you like JD?
JD jetting kits are fine.
the needle in the dynojet kits for the FCR have too much taper.
im gonna get the JD, thanks
what needle do you suggest?
JD told me red needle on 5th or 6th clip. Then as it gets hotter, adjust the fuel screw acordingly, turning it in
I already have the DynoJet kit. What will be the outcome of using it with the needle with too much taper?
  • Similar Content
    • By whiteduke13
      Bought a 1999 Yamaha xt350 couple months ago from a guy that hadn't started it since 2011. I started off removing majority of the big chucks of rust from the tank via bolts/vinegar, and replaced the fuel line, and inline filter with a see through material. Additionally I had the carburetor cleaned by a local shop. The shop messed something up and now the choke is stuck in the closed position, but the bike ran fine for two days in a row (about 2 hours each day). A week later it started dying while riding and I believe its because fuel isn't making it to the carb. I've checked the screens on the petcock, and replaced the tubing and filter to the carb. Before having the carb cleaned the inline filter would completely fill up before starting the bike but now only fills to a third of the way. The inline filter goes dry when running thus the motion fuel isn't making it to the carb. Flow through the fuel line is at a trickle when connected to carb but gushes when fed to a gas can. Any ideas to why I'm not getting flow???
    • By Kawasuzuki456
      So I have an 03 rm 125 and I’m having a problem with my jetting. My original 460 main jet that came out of the carb is huge and unlike any jet I’ve seen before. I also ordered a mikuni genuine main jet off of eBay and went to go put it in the carb (440 main) and it’s way too small. Not sure what to do.
    • By AKrazy
      Hello kids,
      Looking to get my second dual sport. Ive been riding for 3 years on my DR200. I mostly prefer single track and technical riding.
      I recently test rode the DRZ on dirt. I liked the extra grunt, but found it too tall for my legs and too top heavy for my riding style.
      Anyway, I like what I've read about the KLX250's suspension and aftermarket mods. I see "easy install" kits and directions all over, but no information as to how the 2018 kid's EFI will change installing these kits.
      Will it require an aftermarket EFI? Or possibly even a carb swap kit?
