yz250 topend rebuild...attempt myself?
My bike needs a new top end and I was thinking about giving it a try myself. I have never done it before nor have I ever seen it done before. I have very little experience working on cars or bikes. I am a pretty smart guy and am very good at problem solving.
I would really love to know how to do this and it will save me some money and give me confidence to do just about anything else that would be needed on my bike.
Is this something I should try myself? How hard is it really?
By the way my bike is a 05' yz250
The beauty of the 2 stroke bikes is their simplicity. Most anyone can do a top end on a 2 stroke. Get a manual read over the procedure. Lay out the tools, get a clean work space and tear into it. There shouldn't be any specialty tools required just a torque wrench. One of those pipe spring hooks helps alot in removing the pipe. Get a piston kit with the gaskets and you will need to drain your coolant system. The bore can be cleaned up with a scotchbrite pad. I would clean the carbon off of the combustion chamber and remove the gunk from the powervalve while youn are in there. I am no master mechanic but can pull off top ends rather easily both 2t and 4t.
The hardest thing about the whole job is putting the little circlips in that hold the pin in the piston. Just be careful you do not fatigue or bend the little clips, and don't drop one into the bottom end either.
its a very simple job to do if you just take your time and go step by step. The side of the piston will have a relief cut into it to make getting the C clips on and off. if you use a small screwdriver in this relief you can pry them out without damage but i highly reccomend new ones anyways. they should come with a new piston. When you get the cylinder and head off and your ready to take the piston off stuff a shop rag down around the connecting rod so if you do accidentally drop a cclip you dont have to go fishing around in your case for it. Also make sure everything is clean and dry around the area. you dont want to fill your case up with dirt. You have to drain your radiators but you can leave them in place(the lowest bolt on your waterpump is the drain). you must remove the tank. taking the subframe off makes things easier as well but its not needed.
jfgjr is right, there are no special tools required. the biggest thing to look out for is the locating pins that are in your piston ring groove. you need to make sure your rings are in correctly and that the gap in the ring lines up with this groove. ive seen people get this wrong and try to force the piston back into the cylinder and it never ends well.
when you go to reinstall your cylinder over your piston you can easily compress the rings by hand.
when the new stuff is in there will be a small breakin procedure but nothing like a new bike. you just have to be sure you seat the rings properly.
everything will be covered in detail in your manual.
good luck
agreed, the clips are the hardest part, i learned on tt to work them in with a flat screwdriver, this is the easiest and fastest way i have found to do it.
How did you manage to leave the rads on? I think I had to take mine off as well.....or assumed I did. The 97 needed them removed. Leaving them on would be really nice. I will try it next time.
Yes to the question should you rebuild this yourself. Go slow, use your manual and ask questions if your unsure of anything.
The best part is not the money you saved. There is something that happens inside once you get the bike back together and start it. The feeling is great.
You can leave the rads on the steel framed YZ250s (02-04)... I've done it at least six times.
I haven't done it on my Al framed YZ yet so I can't comment...
Definitely do it yourself. It's great to do your own plus you can ride it later that day with no waiting on the shop to get to it. Plus if by rare chance you snag a ring or drop a circlip into your case because you didn't throw a rag in there, you don’t have to drive to the service shop to yell at someone. You can just throw a wrench through your own garage window and still be riding an hour later.
It never seemed like the radiators were in my way so I left them on. Just make sure the piston is all the way down when you take off the cylinder.
Thanks for the tip on leaving the rads on. This will shave at least 10 minutes from the job. That would have been nice when I did mine when it was 15 degrees.
Redneck just doesn't go outside in that kind of weather :thumbsup:
Seriously... the hardest part that I've found with rebuilding the top end is cleaning to carbon off of the PV... this was on the ktm though. I haven't done a top end on my yz, but i'm not at all worried about it after seeing how easy the ktm is.
If i can rebuild the top end of a bike... anyone can do it. I'm probably one of the worst mechanics on TT.
Thanks for all the great feedback. You guys have definitely given me the confidence to do it myself!
You guys on tt here have convinced me to have a go at doing my own top end rebuild, so i'm going to give it ago at it, i'm just waiting for parts to come in. i was just wondeirng how do you clean up the power valve ? And what with? . As i dont really want to muck around with the power vavles. And also best way to clean the carbon built up on the cylinder and the head.
Aaron
Before you worry much about the pv, look at it. It might be in better shape than you think.
  • Similar Content
    • By Lone Danger
      Ok so I'm looking for opinions from those who have been on yz125s and 150 exc/xcw's and maybe the ktm 200's exc/xcw's. You gotta be out there.
      Here's the deal...I'm 5'7" 165lbs. A couple years back I was looking for a small bike for my wife to learn on and for me to play around with and race. Could only afford one bike. I got a '09 ktm 105 sx. Once I got it sprung for my weight it was great. I have been top five consistently in my local harescrambles B class, believe it or not. Ya, you were not the only ones shocked. And did pretty good in the local mx races as well, junior class up here in Canada. Lack of power was sometimes an issue but I learned to deal with it and just scream, scream, scream!
      However my wife is a complete beginner and she is scared of it. I have since moved her to a 4 stroke.
      Just got a mint '01 yz15 mid summer. Like less than 200 hrs! I have absolutely loved it on the mx track. Suspension is perfect and I love the extra power. I had planned to set it up for woods/mx with a suspension revalve. However, did a harescramble race a month ago that was really technical. Granted I have not done anything to the suspension minus clickers, had too much psi in the tires (13 front and 15 rear) (yes I know that's wonkey, I only had time to get a heavy duty tube in the front and had a stock tube in back. Less psi in the back would have been instant pinch flat because its so rocky) and it was running rich. I had to scream the thing to keep it running and even changed a plug mid race. Well I'm sure you can guess but it was the worst experience I have ever had on a motorcycle. The more open sections I passed a lot of people but the tech sections required way more effort than I liked and the suspension beat the hell out of me!!! Like my knees, wrists, and shoulders were just done. (I was out there for three hours).
      So keep in mind that I just came off a 105sx with suspension mods (set up for woods/mx). I have no problem slipping clutch and shifting precisely, yatta yatta. (I don't think the 105 would have done well here either due to even less power, however...) I've been second guessing fixing this 125 up for woods ever since I rode a friends '09 ktm 250xcw. I rode it on a local mx track. The power was just so effortless and I was absolutely floored by how the suspension worked. I never thought that I could hit the woops that hard and clear every jump on the track on an xcw and feel THAT good! It felt a lot heavier though, and I think the price tag on these things are going to be a stretch.
      So here's my question. I want the lightness of a 125, but want to be able to race both woods and mx. How does a 150 exc/xcw ENGINE compare to an mx 125 engine? I love the 125 engine, but more low end would be usefull in tech areas. But if there is not a huge difference, I will probably just revalve the yz for woods and go tubless, etc. The 150exc's are so expensive and I hardly ever even see one for sale unless its brand new. I don't want the weight of a 200/250/300. I barely touch the ground on a 125....so it has to at least be light. Is it worth waiting for a 150 engine? Thanks guys.
    • By doolan
      Hi guys I have a 2018 yz250 looking at changing springs front and rear I'm 200 pound ride b class moto.
      Having problems choosing spring weights using the calculators as mx tech say I need .45 fork springs and 5.2 rear but racetech say .48kg forks and 5.8kg rear.
      What are other bigger guys
    • By YamahaYz1
      Hey TT, I know there's endless topics on YZ250/ two stroke tuning in general but I have not been able to find one that helps me get my 09 YZ250 set up for my riding style and where I ride so I'm here asking for help. I got this bike around 1.5 years ago and have not known how to set it up properly. I know no one can give me a perfect set up but I'd like a good starting setup to work from and tweak to perfection. Throughout this time I've had this bike, its always been covering the bottom of the entire silencer and dripping all over the swing arm and rims with oil. Also, the joint between silencer and expansion pipe has oil around it too but I've heard I have to close the gap a little to squeeze the silencer a little tighter and stop the leakage there. I don't have too much experience messing with carbs but I've messed around with previous two strokes and tuned them a little better. I change the oil on my bike after 15-20 hours on it and clean and oil the air filter after almost every ride. The sparkplugs never last me more than a few months but recently have been lasting me no more than a few weeks. With the excess oil from the pipe and spark plug fouling you can see why I need to set my bike up to stop this.
      The bike:
      Completely stock with V-Force 3 Reeds and a FMF Shorty silencer.
      Usually running around 32:1 premix with 91 pump fuel because I prefer to keep it well lubricated instead of running rich.
      Riding:
      I ride enduro in Ontario, Canada. So mostly single track and some fire roads but nothing close to MX and not a lot of time wide open. Therefore, probably mostly 1/4-1/2 or 1/4-3/4 throttle range.
      Where I ride:
      Usually 0-500' above sea level. With temperatures ranging from around 15-35 degrees Celsius (55-95 Fahrenheit).
      If anyone can give me a setup to go from, that would be very much appreciated. Even multiple set ups for different temperature ranges or any suggestions would be much appreciated. Thanks and sorry for the long read, I just didn't want to leave anything out. Ask any questions if you have any, too.
    • By Goon Rides
      Hey guys... so I have a problem... I took the bike at Cal City, broke it in, and while I was doing so, the bike was bogging in first gear (Yes, first gear). Also it doesn't idle at all. I have to keep blipping it otherwise it'll stall. So I adjusted the screw circled in image 1. Well I was listening to the sound of the of the bike, yet the rpm's weren't increasing, and it was still stalling. So then, I unscrewed the screw in image 2, well I found out that it was fully twisted to the right. So then, I twisted it to the left, still nothing; it was still stalling... where's the idle screw? I am sure that the screw in image 1 is for the air/fuel mixture screw, and the screw in image 2 is the idle screw, just broken? I don't know, any and every help would be appreciated.
