Stupid Q of the day - Oil change 08 te450 - HOW?
I have been busy, so have only had a chance to read book quickly. My time to do an oil change this week is going to be very limited, so when I get that chance I don't want to find that I don't know how to do it. I have a CRF250x and have been maintaining that. This is my first Husky. Only had it for a couple of weeks. I have drained oil and re-filled on husky no problems, but there seems to be 3 or 4 filters. Does anyone have any photos of them. I've run a quick search onT/Talk and didn't find anything. any tricks I need to be aware of? I just want to make sure everything runs smooth and no surprises. I have purchased a new oil filter. I guess the others you just clean with fuel or something.
From the photos I've seen of the '08 motor, it appears the same as previous non-injected models.
Look on the left side of the motor, below the stator cover. One alum cover with two 8mm head bolts. If you already put new oil in, then lay the bike over on it's right side. If the oil is out, then there will be some residual oil that will come out - just so you know. The cover you remove has on O-ring on it, and I use my pinky to reach in and pull out the simple-rolled screen that is in there.
Towards the front of the motor, next to the alum cover we're talking about, is a 6mm recessed-hex bolt. Remove that bolt, and there is a small o-ring and then a fancy screen, which you may need to be creative with to pull it out. NOTE the orientation of how it comes out! On reassembly, there is a step inside the motor when you put it back that it needs to get into properly. Then get the O-ring in there ... which I always get nervous about it getting crushed in there, but if you are careful you can convince yourself its okay. Maybe a little dab of grease wil help it stick where you want it.
I check it every other oil change - it's not that hard, however I think the manual states it doesn't need to be done that often.
Good luck,
Adam.
cool - thanks. It's getting its first service this week. I just like to know how to do these things. I've put new oil in it twice, but haven't done filters as yet. It's brand new, so trying to be careful. I did oil at 95kms and at 130kms. time to do filters. Dealer had no problems with that.
Cookie, as Adam said in his post and remember be gentle when doing up the filter cover bolts, Just clean the screens with fuel.
Drain it warm,
A good tip if you haven`t taken screens out before - Mobile phone picture of the way they came out, it`s not hard to do right but easy to do wrong !
Just do things up firm, don`t lean on the bolts / threads will die
Husky Brothers : Brilliant - thanks.
Ioneater - thanks for posting that.
Okay now I'm happy - doesn't seem like that long a process. Husky certainly like filters compared to the Honda. The Hondas ONE filter is even smaller than the Huskys by the look of it.
that bike you used is damn clean - looks brand new. My 2 week old new 08 Husky looks older :thumbsup:
should I do the front screen too? it will be it's first filter change
i always change the filter & clean both screens, new oil every 4-5 hours when racing or 15 (ish) hours forest riding.
Biggest killer of Husky (any HP 4T) is bad oil
i've never asked this, but how many miles/kms would 15hr or 5 hours be?
I think my bike had 5 hours on it at something like 150kms?
Is the hour meter on the instrument panel engine hours? the same as the aftermarket engine hour items?
Yes - if the engine is running, then the clock is ticking. For me, it's more about hours run, than miles run.
  • Similar Content
    • By 305hestbeck
      So I just sold my bike 2017 TC250 with only 17 hours on it. When it left it was in brand new condition. But 2 days later the engine cases were being split.
      Turns out the Idler gear had snapped off during the new owner’s first ride. Of course I am not paying for the fix as one it is clearly a manufacturing defect. I told him If needed I would help by me claiming it as warranty issue.
      Anyways I did some research and discovered that the KTM/Husky expected a 6x12 to hold the idler gear sys together on 2017.
      Well this seems to be an issue and KTM did fix it for the 2018 models. They actually updated the whole Idler gear sys, but if you still have a 2017 2 stroke the fix before it happens which it could on the first kick would be to replace the bolt with a 6x20.
      You will have to tap the hole for more treads. Actually the 2018 engine case was also updated for this and that’s all they did.
      I own a 2018 TX300 now. One reason why I looked into it.
      Just thought I would share.
    • By Tranos07
      Greetings to everyone. After a lot of searching I finally decided to join this forum in order to finally find a solution to my problem. Here's my story. Bought in a hurry an sm610 2005 (cylinder with the small tensioner) which wouldn't start cold. Only if I connected it to a car battery would it start but not always and not easy. Got a new 14amp battery and nothing. Spark plugs,starting spray etc nothing worked out. If the engine was cold it would start in an instant very very easily. Took it to a mechanic he told me that it had no compression so he grinded the valves. When I got there to take it back he told me that my pick up coil was in bad condition and needed to be replaced in order to start cold. Of course nothing changed after the valve job and after 5 hours of riding(not constant) my new head gasket blew and when I took it apart I found a crack in the water passage on my head right next to the blown up spot on my gasket. I don't know if it was already cracked or if it cracked after gasket blew all I know is that it was tightened properly as I was in front when this happened. I'm just trying to figure out why i can't get it to start cold. All answers are welcome. I had the head fixed and I'm ready to reassemble the engine. Could the pick up coil actually be responsible for this? Another thing I noticed. My tensioner had an apostate welded up to it so i needed a new cam chain as well as a new tensioner. I have these. Could the ruffled chain be in charge? The engine was perfect when hot starting and working like a charm. Please someone help as I'm ready to take the damned thing and throw it into the ocean.
      PS is the pick up coil from an lc4 engine compatible?
    • By birdland101
      Restored 1974 honda xr75 original motor and frame podercoated frame runs, looks, shifts, stops good. top end rebuild many new parts most all honda. email birdland101@hotmail.com.
    • By Jawehangwe
      2017 Husqvarna TX, TE, FE, 125, 250, 300, 350, 450, 501
      Greatly reduced arm pump and fatigue
      Increase rear wheel traction while standing under acceleration
      Create a seat bounce effect when jumping standing up
      Shave seconds off your lap times
      Light weight and adjustable
      Easy to install
    • By MotoXRacer_19
      As I was inspecting my new-to-me bike that I just purchased, I noticed there is a grove on the back side of my front brake rotor that goes completely around it, and you can feel it with your finger nail. I have noticed some poor performance, but I figured it was because of the new pads that the previous owner installed just before I bought it hadn't seated yet. However, I've ridden a couple times and it doesn't seem to get much better, if any better at all. Is that enough to explain why when I pull in the brake as hard as I can, it only slows me down a little, instead of going into a stoppie and over the bars (as I wish it would)?
      Should I look into buying a brand new rotor?
      I have no pictures of it, I'll try to post some when I can.
