JUst bought a KTM
Hey guys been ridin yamahas my whole life...i just bought a 2003 sx450..just wondering how the bike is, and if there is anything i need to watch for...how often valves need adjusted? and wheres best place to order parts? ill post pics of it later, i guess iit only has 6 hours on it...not a scratch and still factory everything!
Ktm Engines are the most reliable and fastest. better than yamahas. you shouldn't have any problems, maybe getting use to it. that was my problem.
I hate to be the one to tell you this but the 2003 450 SX was a suspect machine. Factory got a bad batch of Ti-valves which in turn broke. KTM even recalled a great number of these bikes so they could update those valves.
Most -03s out there are fixed by now but it´s better you check that out with the previous owner.
Later batch of -03s had the problem corrected before they even hit the dealers.
ouch...never heard of that
zackbothbike015.jpgzackbothbike013.jpg Here is my bike..how do i get the rust of the pipe? any ideas?
? any answers to how i get that rust off the pipe?
WD 40 + Scotch Brite + Elbow grease = Better looking pipe:prof:
Yeah ,ouch... My friend made a Sallad of his -03 450 SX engine back in -03. It dropped one valve in the end of a high speed straight.:thumbsup::eek: KTM replaced (updated to -04 parts) everything under Warranty.Go to KtmTalk and do a search. You´ll find plenty of info about the subject.
2003 was a dark year for KTM. Their 450`s had bad valves (some of them) and the first batch of 525`s came out with wrong CDI-unit (from a 450 SX) which allowed the mighty 525 to rev way past their peak revs... They also had a bad batch of triple clamps that year. Those cracked... Everything was replaced under the Warranty though...
thank god they fixed their errors before it would go into next year...
I moved to KTM from Yamaha in 04 But was told buy lot's and lot's of people not to touch them due to the bad valves ect from the 03 bikes due to the amount of failures people were having. I must admit I never had a problem with any of my KTM's and they are so good to ride.Check that you have had the recall and you will be fine.
You´re right about most bikes being fixed by now. I have never had any troubles on my -03 525 SX either but the dealer called me before i had a change to break it. It had the wrong CDI-box (from a 450 SX) and faulty triple clamps.
I just wanted to make a point about some problems the -03 SX´s had. Most likely almost all bikes are fixed and there´s no worries but i would hate to be the one to buy a used -03 bike and see it destroy itself - all because i didn´t know better. A sight over the engine internals after a major melt-down can and will make a grown man cry...I´ve seen that happen. Honestly ! So Kounkel ; check that this exact bike has got everything replaced. You can do it thru KTM or thru a KTM dealer.
  • Similar Content
    • By Workerbee33
      I have a 2008 ktm 505 sxf, I am curious if anybody has installed the ktm hard parts fan kit or enduro engineering kit and if the mounting brackets work or did you have to fab something up? With a low output stator was it to much for your battery? Local ktm dealership says they think the 505 xcw fan kit will fit the 505 sxf...I do have an aftermarket tank
    • By To_the_holler
      Greetings
      I recently purchased a 2010 ktm 250 xcfw champions edition. (aren't all 2010s champions editions?) I am having a few issues with fuel and coolant that may be related.
      Relevant modifications: Previous owner had installed a quick shot 3, and an FMF F4.1, but claimed the bike had stock jetting (more on this later). Also claimed the bike got new piston and rings recently.
      First ride went mostly well. Exception being the bike needed an exceptionally long time (several minutes of riding with choke on) to warm up before it would idle with the choke off. Is that normal? That and I think the silencer was more of a loudener and practically made my ears bleed after a few hours.
      For the second ride I installed the factory silencer for everyone's sake and assumed the jetting would be fine since previous owner claimed it was stock. Bike ran fine until I came to a stop and noticed quite a bit of steam rolling out of the crank case vent hose.... Assuming the head gasket just went, I shut the bike off and called it quits.
      So I ordered and installed a new head gasket and lower cylinder gasket. Piston looked pretty new and so did the gaskets. I also could not find a "bad" spot on either gasket where coolant was making its way into the oil/crankcase. Here's where I may have messed up. When reinstalling the timing chain tensioner,  I don't think it properly "clicked" back into place because the bike would not run after reassembly. I pulled the valve cover to find the exhaust cam had skipped 1 tooth.  So I reset that and was more aggressive with the tensioner and got it to properly seat. Bike fired right up and seemed to be ok compression wise. I put new oil in, rode it for 5 minutes and then changed it again to somewhat flush out the coolant contaminates.
      Does anyone think the piston struck any valves if they were only 1 tooth off? Wouldn't I have heard them clank together when trying to start it or felt the extra resistance when kicking it over? (Bad battery at the time so no electric start)
      Took it out for a third ride with new head gasket and fresh oil and it seemed harder to start and wouldn't idle properly with or without choke. After gently riding it for several minutes it would still not run properly. It had a surging idle and would sporadically die. If throttle was applied it would sometimes respond or sometimes die. Then I noticed the steam beginning to exit the crank case vent hose again. It seemed to run ok anywhere above 1/4 to 1/2 throttle. Great power response and felt smooth. Anything less and it was dying or surging up and down.
      So I installed a new water pump shaft seal, and side cover gasket hoping that was the cause of the coolant leak. Then I went after the carb to see if something had become clogged. A complete disassembly and cleaning revealed a surprisingly clean carb with the following jets: #172 main jet, #45 idle jet, and #85 starter jet. Needle jet clip was on the 5th position from the bottom. Nothing seemed to be clogged or malfunctioning.  I inspected the intake boots for cracks/leaks and everything seemed to be fine there. After reassembly there was no improvement. I then tried every combination of air screw and qs3 adjustment possible which didn't seem to even phase it. The only thing different I noticed is after several minutes of poorly running and attempting to tune it, if I put the choke back on it would almost instantly begin to rev up uncontrollably high until I turned the choke back off.  And then to top it off I still have steam coming out of the crank case vent. I'm hoping the steam is somehow leftover coolant from before and not something like a cracked head or anything. I gave the head a good look over when I had it off for the head gasket but I wasn't really looking for cracks back then.
      Any ideas on where to go next? Could these issues somehow be related?
      Sorry for the giant wall of text but if you made it this far thank you. Any thoughts, ideas, jokes are welcome.
    • By prorider17
      For sale is a new right-side OEM radiator + cap from my 2015 Husqvarna FC450. Could possibly fit 2015 KTM 450SX-F (since it's the same bike, but in orange).
      Asking $60 + cost of shipping. Photos: https://photos.app.goo.gl/pvVqTcrMeczQhHaf1
    • By KyleHubert
      Hey guys, what do you think would be a fair selling price for a 2015 ktm 250xcfw? It only has just 15 hours on it.. as i mangled my back and haven't been able to ride since.
    • By johnny125aao
      So i was about to get a crf250r until i went to the ktm dealership and checked out a 2017 ktm 250sxf. i just wanted to know what thoughts people had on these bikes. I have always ridden honda but would like to know more about the ktm. reliability, handling, resale, and any known problems .
