2008 Ktm 450 Xc-w(r)
XCR-W is the wide ratio 6 speed, basically an EXC without the road legal stuff. It is notoriously lean in the mid throttle positions due to a needle that has too little taper. Screwing in different jets does not fix that, it needs a needle with some taper. The JD is the simplest route.
I'm running the F2 blue needle in the 2nd position, with 162 main, 45 pilot and fuel screw at about 1 turn out. I'm at sea level to 1000'. It has been running a bit rich- hard to start when hot, cold starts no choke. I'll try a 42 pilot next and see if better. Yesterday there was a little missing wide open. Not sure where that came from.
