first time starting motor
. i am soon to be getting my motor in the mail, being that it more than likely has been upside down for the majority of the trip . what is the first thing i should do prior to starting the motor? etc, oil change,or anything else?
1 Change the oil I recommend using (Non Synthetic) Only
2 put in proper recommended Levels
3 Heat cycle motor at least 2 times before actual Ride
(Bring to proper opereating temp and then let completely cool under no more than 1/4 throttle revs)
4 I change my oil (before the actual ride and after) but you can re-check the level and ride shifting smoothly and not using more than 3/4 throttle for an hour
5 let cool, I then re-torque my head bolts and adjust my valves
6 after about another hour or so I have at it using full throttle (respecting conditions)
Very good advice there! but you forgot
7. Whip up on you buddies rides!!!
I was hopeing he could figure that on his own....:confused: Hahahahaha
thank you for all your great input... when you say re torque, do you mean tighten the engine bolts? and how do i adjust my valves? im sorry for the 21 q's just never had to do any of that with my kx80 or maybe just never cared lol
Re-Torque the (Head bolts) and should be periodicly checked throught its life...IMO
Torque Specs:
Refer to an approved Honda CRf50 manual for all the torque specs. Carefully following torque specifications is important.
i thought adjusting the valves were hard but that looked simple enough with the right tools
Everything in life works better if your equipped with the right Tool .....:confused:
Torque Specs:
how wouldi get my hands on a crf50 spefications handook anyways?
thanks everyone..2 more days till my motors here:ride:
