Wheel Truing Question
So...I got my wheels laced and trued today but my questions is...how do I get everything tight. Even though its trued, there are still loose spokes. Won't if i tighten those its going to throw everything off. Thanks in advance.
Start at the valve stem and tighten every 4th spoke. Once you go all the way around start at the 2nd spoke from valve stem and then tighten every 4th one again the same untill once around. Then the 3rd from stem and every 4th, then 4th from stem again the same. This will keep your rim true as you tighten them.
doc
