BRAND NEW 07 KX250f
just brought mine home from the dealership stoked ill have pics up tomorrow hopefully:ride: :confused::excuseme:
oil the air filter grease linkage and swingarm. mine were good so i didnt mess with greasing the headset. put an hour meter on it
what do you all use for hour meters? I have them on all my lawn mowers that I got from the mower shop for like 25 bucks. anything smaller/better/cheaper?
alright thanks ill take a look at the air cleaner it never crossed my mind that it wouldnt have oil on it
Didn´t you get the headset for Kawasakis integrated intercom???
Haha, no he meant the steering stem bearings.
And change the oil and check/change oilfilter after ½ to 1 hour of running, just to be on the safe side!
i bought one from sears in the lawn mower section for $30. same thing as dr. d sells for what $45 or so? use electrical tape or zipties to zip type it to your frame under the shroud. I rode 1.2 hours on the stock air filter(outside had oil on it) but when i took it off it was completely dry on the inside of the filter. Also check the valves I had to shim all 4. Dont forget to check spoke tension too and go over all the bolts after the first few rides.
i just picked up some hour meters on ebay for 20 bucks each. They seem to work well.
im thinking about investing in one of thoughs ill go check out sears
i just put locktite on most of my bolts checked the spokes
the aircleaner had some oil but it needed a sealant around the edges but other than that its ready to ride :confused:
Do yourself a favor and tear the whole bike apart and lube the entire chassis. This a great way to learn how the bike goes together and then after evrything is lubed, get yourself a torque wrench and torgue everything down and your good to go
