Cheap SM's on the way to New Zealand!
Hey all - first post for me, waiting on my new white and blue 08 SM to arrive - there is a shipment coming into New Zealand at $7995 (about $6400 US) down from $11990. If you want one get in fast - especially a white one as most coming in are black.
Can't wait! Am getting dirt wheels and tyres for it too. Thanks for all the awesome info on here - I intend to all types of riding on it from commuting to track days and dirt racing.
Cheers :confused:
a white one you say, that'll look smart. price sounds good ,specially when u consider that the road kitted "e" is over 9k.cant wait to see one
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
