shiver oil change
I want to change the oil in my shivers (X4r 2008) - How, what type of oil and how much oil. thanks.
How much do you weigh..?
7wt at (80mm-90mm of air gap) is what comes stock
if your above 180lbs Id suggest a 10wt fork oil at (80mm-90mm of air gap)
do not use above a 10wt Fork oil in theses forks without consulting a Marzocchi Rep!
And use fork oil, not motor oil. (you probably already knew that, but it get's asked here all the time)
