racetech sheets for showa
hi guys,
has anyone a copy of a race-tech valving sheet for the 50mm showa?? - could do with looking at one thats all.
just need to see if its the same as the kyb one i have.
thanks.
mark.
hi guys,
thanks.
mark.
Let me check, I picked up some stuff from a guy who did Race Tech stuff, I think I have some sheets.
that would be great - i also need a ktm one if you have it.
i have a kyb 46mm sheets if anyone needs one.
mark.
Ok, finally remembered to look for you and I have the 50mm chart, will be glad to fax it if you have a fax #. I did check it against the KYB chart and they are mostly the same but the compression stacks start out with 40mm shims instead of 38mm. Rebound stacks are identical, low and mid comp are the same but for the 40mm shim, the high speed stacks are slightly different but not enough you could not work it out.
Let me know if you wan't the sheets.
that would be great - is there any way you can e-mail them ?? scan or photo them?
i dont5 have access to a fax machine sorry.
mark:thumbsup:
If you wan't to send me a PM with your your e-mail I will try and figure out something.
thanx to mxracer206 - he's sorted me with the showa stuff.
im still looking for some ktm sheets if anyone can help!!
thanks guys.
mark.
