02 450 head pipe
i am a newbie at this site just to let you know. anyways i have a 2002 450 and the head pipe is cracked so do you guys have any suggestions as to what heap pipe i should replace is with. also the bolts to put the head pipe on are impossible to put on, i can get the top one on fine but the bottom on the welding for the frame gets in the way. so if you could help me with that i would greatly appericate it
thanks
Just buy a stock replacement for real cheap on ebay.
thanks
how do you get the bottom bolt on? would a thin wall socket fit or should i file down the weld?
you shouldn't have to do anything special.
i just use a ratchet & extension.
sounds like your pipe is pretty messed up.
ya maybe the split expanded the pipe
thanks for all your help
no problem.
you should check out ebay though.
I believe you can use an 02-04 head pipe. You may want to search around on this board for confirmation of that.
To get to the bottom nut, use a 1/4" drive ratchet, long extension and socket.
It easyily fits, that's how I always install and remove mine.
When I crushed my header, I also had to use a pry bar to pry the header away from the frame before I could get to the bottom nut.
