back bleeding magura clutch
Im tring to back bleed the clutch on my 200. But I cant force the fluid in. Yes the top cover is off and I have the bleeder valve cracked. WHat do you thing is wrong? thx
I had the same problem. Check to make sure your lever adjustment is backed out. If it is in too far the master cylinder piston can be blocking off the resevoir not letting fluid in.
Make sure the bleeder valve isn't clogged with dirt. You may have to take it all the way out to check it.
Mine did the same thing. Took a rebuild kit to fix it. Either the spring was sprung, or the o rings swelled just enough to drag and not let the piston go back to the home position.
