'07 YZF250 oil drain bolt issue
I was changing the oil on my bike the other day, and when I was screwing the bolt in which is in the frame behind the front tire I noticed it wasn't tightning up. It felt like I had a bolt that was too small for it. So I removed it thinking I had mixed it up with one of the other 7 bolts you have to remove to drain the oil.
When I removed the bolt the threads came with it.
I was screwing the bolt in with my fingers and the threads on the bolt arn't messed up.
Someone told me they had, had a problem with the welds in the area, on their bike I guess they didn't hold, and they lost all the oil.
I was wondering if anyone else heard of any recalls on this. Or if you just have any information on this.
I had just warmed it up and I'm wondering if it had softened the metal and caused it to happen or something.
I'm at a lost I've never had anything like this happen before.
Please help with any information you have. Thank You!
One thought would be to drill and tap it for a 7 MM bolt. Maybe a helicoil. Call your dealer or a mechanic if you know one. At least it is easy to get to.
This had to have happened to others, especially the oil filter bolts. I've never had a problem yet but aluminum is pretty easy to strip.
You obviously overtightened it.
ya i think im gonna end up tapping it, I take an automotives class so i can do it in there pretty easily.
Thanks for all the help
