450 EXC Lower Oil Screen Bolt Stripped Out..
Ok, so I've heard this is a common problem apparently..the (8 or 10mm?)allen key lower oil screen bolt is stripped out on my '04..
I'm ordering a replacement hex head bolt from BrapOffroad.com
BUT, I just wanted to post and see how you guys recommend getting out the old bolt..A mechanic friend of mine said he usually trys hammering a socket star-key into the allen-key hole and seeing if that will work first, but ya..Any suggestions??
I work in a machine shop and we use an item called "sock-it-out. that will fix your problem. available at most hardware places or check out this link.
good luck and dont curse too much while getting it out:mad:
little heat and rest as said above
Nice. That looks like just what I was need!
same thing happend to my sx and i did exactly what they said little heat and an easy out socket type and it came right out
I tack welded a smaller bolt into the sockect and used a wrench on the bolt to get mine out.
Had the same problem and ended up going to snap-on's web site and ordering a straight extractor kit. You can go there and search part# E1020. This kit was highly recommended to me by a couple people who ride. It's a little pricey but I used it and it worked great. I have tried cheaper extractors and stripped the splined on them. This seems to be very good quality. I just about passed out from sheer joy when the damned thing actually came out. I too bought the aftermarket bolt, Slavens in my case, and a little anti-seize on the threads and am looking forward to my next oil change just so I can remove it easily. :confused:
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
