How to get to leak jet?
What exactly do I have to do to get to the leak jet and where is it located?
All you need to do is pull the float bowl.(if you have after market fuel screw, it will need to be pulled first)you need a short screw driver(or philip bit) to pull w/carb installed.The leak jet is in the float bowl.
good luck
:confused: lets ride:ride:
Ernie
