metal cast spray paint
has any body ever used this how does it hold up
Not very well. It really depends on what you paint with it too. There's been a few threads about it in the past with some good info.
damn i always forget to search
and its a go cart frame
duplicolor? i have had good luck with it, its all in the prep work...
wat is the prep work
can some 1 post pics of their anodized spray painted products
what is the prep work??
well..
good cleaning with paint thinner, good sanding, clean again, prime, sand primer, clean again,...then paint....
well..
sorry i always forget the h lol
what grit sand paper should i use
and how many cans do you think i need for a go cart frame
start with like 500 grit, and end with around 2000 with the finishing sanding, try to get all the rust off... you will need about 4 cans...
aight thanks
