Spark plug change
who has the easiest way to change a plug. I just did it today for my first time and it was a B!^ch. Or is there a special tool that makes it easy?
The wrench in the owner's tool kit makes it a piece of cake. If you don't have one, yeah, it won't go very good at all.
What year & YZ/WR are we talking about? On my 05 WR & YZ, I can pull the plug w the tank in place.
yeah that tool is awesome, the spoke wrench connects to it as well
I have the following process:
Pull plug wire off
Put 5/8" socket in the hole
Put extension in the hole
Put swiveling extension on top of that if needed
Put rachet on extension
Loosen until it's good to go
Remove all extensions
Grab plug with spark plug boot
This assume that you don't have the swiveling socket, that makes the job a hell of a lot easier. I have one now (came with my FZ6) but I didn't before. I did it the way I just described.
Use or buy the one from yamaha that comes with the bike and a 14mm wrench, i changed my plug yesterday with it in about 2 minutes, did't remove any parts other than the spark plug cap.
should have came with a folding type spark plug wrench you can change the plug without removing the fuel tank - it has rubber insert inside which will allow you to grab the plug and pull it out, as well as hold the new plug and allow you to put it back in.... good tool... should come with the purchase of a new bike, along with a spoke wrench, needle removing tool, a few jets, a service manual, and thats it i think....
The right tool for the right job is always a plus. Then again you might think it's still a pain, because it's a cake walk to start with. I use a socket, extension, and ratchet.
5/8" plug socket i believe(if you lost the one that came with the bike). a deepwell could work too. there are small threads on the top of the plug that thread into the rubber boot. when removing the plug, disconnect the rubber boot from the wire harness thing and kinda of unscrew the rubber boot off the sparkplug, then take the plug out. vice-verse for installing it. check your plug gap prior to installing-(.028"-.031"). u could just rip the rubber boot off the plug, and jam it on the plug instead of threading on/off, but i dont see y u would want to do that. idk, should be a super easy task.
I used a regular 5/8 plug socket but the rubber thing inside was too big to grab the plug after it was loose. I must not have gotten the tool kit with my bike cause i bought it used.
The wrench can be found on the "frame" section of the Yama parts fiche. From Yamaha of Troy-
#5TA-2814F-00-00 $11.21
you dont need the plug wrench that comes with the bike. its actually pretty cheap anyways. especially for $12. just use a 5/8" plug socket with a small extension. heck, u can use ur fingers or some needle nose pliers to get the plug out. just dont drop it back in though(u can still use your fingers to put it back in, just be gentle with it.)
