OK Let's see the OFFROAD KX 450's!!!!!!!!
I'm going to set up my new 08 450 as my woods weapon and wanted to get some ideas. Pics are always nice too :confused:
I'm just getting started but here's my list so far:
Hour meter
Utah Sport Skidplate
Cycra Handguards
Renthal 52 tooth rear chainring
RK Chain
Z-Start Rekluse clutch
Left hand rear brake
PMB kickstand
PMB Spark arrestor
PMB Ultra Quiet tip (gotta keep the trails open)
Next on the list is:
IMS or Clark fuel tank
RTT Steering Stabilizer
Can you show us a picture of the PMB end cap? I want to get one, just wanted to see how it fits in the stock cannister.
Aaron.
Aaron.
Sure,... Here you go.
The pipe was still a little too loud so i made the following modifications:
I ended up disassembling (sp?) the silencer and checking it out.
I ended up drilling some of the existing holes a little larger and then driling about 150 more holes in the inner pipe and then repacking the silencer. I blew a 93 this past weekend!
Here's a pic of the holes I drilled out larger.
Here's a pic when I was halfway done drilling the additional holes.
pertty good idea:thumbsup:
hey wr426inAZ who make that skid plate
So drilling the holes helped quiet it down? What was the DB before? Did it have any noticable effect on power? I just got a pretty nice DB meter and have some extra Q-inserts for my MRD exhaust and was going to experiment with some different things.
I got some new graphics and a bunch of other new stuff for mine. I'll try to get some new pics up soon. In the meantime there's an old photo and a list of my mods in my garage.
Got it through Rocky Mountain. I believe it is a UTAH Sport skid plate but it came with Richochet stickers,... so I don't know for sure.
Thanks for the pics of the PMB!
Hour meter
Skidplate
Handguards
RK Chain
PMB kickstand
PMB Spark arrestor
Your off to a great start, you just got the bike:worthy:
Looks like she's coming along nicely.
Hey im new to the KX 450. Got a question I ride in sand and im worried about the crankcase vent tube has anyone had problems with sand getting into the motor from the vent tube? Ok I uploaded a pic of the filter I put on.
With the stock packing and the PMB Quiet tip I tested at 98db.
I drilled additional holes and repacked the pipe then I tested at 93db. :confused:
It is down a bit on power but I really don't need it all for the tight racing I do.
It's a small price to pay to help keep our trails open.
When I go to a track I'll remove the quiet tip and unleash the beast!
Is it down on power from driling the holes or the quiet tip? I am planning on drilling holes with my stock can with stock tip to see if it makes it quieter.
What is a LEFT HAND REAR BRAKE????????
never heard of that
good Idea :confused::excuseme:
Down on power from the Quiet tip. It reduces the exhaust opening.
never heard of that
When I install the Rekluse I no longer need the clutch lever so I remove it and install a left hand rear brake setup. I also remove the foot brake all together.
I can modulate the rear brake a lot better with my hand. It's really nice in tight technical downhills. :confused:
Gidday wr426inAZ,
How do you find the Rekluse was it easy to get use to ? also the back brakes on the bars was that hard to get use to?
Gidday wr426inAZ,
I have a rekluse on my crf450r, and the left-hand rear brake took hardly any time. Of course I get teased relentlessly by friends for the "7 levers I have on my bike", but they're the ones laughing when I can rail a tight right hand switchback.
Gidday wr426inAZ,
I've been riding with this same set-up on my KTM for the last two years. It's hard riding without it now.
Took maybe 3 rides to really get used to it.
It's just like a bike (except that the brakes are switched).
Like "kreativecid" mentioned it's heaven to be able to rail a tight off camber right turn in the woods and put your right leg out. :confused:
