2002 CR125 Rear Wheel on a 1999 CR125
I recently purchased a 1999 CR125 but the rim was cracked. I found a complete 2002 CR125 Rear Wheel and was wondering if the wheel or just the rim was the same. Thanks.
Thanks, that is all I needed to know. Just got to figure out the coolant mixing with oil problem now.
most likely its a bad water pump seal. :confused:
The rim can be welded at any welding shop. Most likely it is cracked where it was joined together originally.
I had one more question, will a 2.15x19 rear rim work on this bike? The stock was a 1.85x19 if I remember correctly. The rim is a 32 spoke hole one. Will all of the stock spokes work with the wider rim?
Yep, it was off of a 05 CRF250R. I thought that I read they interchanged somewhere, but I was not sure. Thanks "KGAWDTS"i!
