smoking klx300
man.went out on my 1999 klx300r for the day. not checking the oil before. after about 4 hrs riding engine started making screaching noise . so stopped and checked oil ,not alot there had to lean the bike to one side till i could see the oil . so topped it up and ran fine did about 3hrs more riding .kicked it up 2 days later after giving it a new oil filter and oil filled to just under the middle of the markings . blue smoke comes out until it is warm then clears . if i do this then leave to stand for about 1hr the smoke is back think i have done rings or oil seals anyone had this problem before your advise would be very welcome:cry:
If you tear down the motor you might not like what you're going to see. I would be tempted to ride it as is but always go riding with a partner that has a good tow strap. The bore and ring damage could be causing the smoke but other parts may have also been damaged. Start looking for a used engine. It would cost more in parts, than the bike is worth to do a complete rebuild.:confused:
its true i just spent about a grand doing JUST the top end, and thats re-using the cylinder. i would suggest taking the top end off and inspecting it before you ruin something. could be something as simple as a ring set and maybe valve guide seals. should cost you around 50 bux or so, maybe worth it?
You should have looked at the old filter closely too see what it caught.
If you didn't get oil to the top of the engine the valve stem seals would be the least of your worries. If the bike was using so much oil that it got low enough to stick it was way overdue for repairs.
A head gasket is around $38, a set of rings about $35. If you lost oil pressure your crank/rod could be the first to go at $500 list price for a new one. And if the cam bearings starved for oil you could need a new head and cams.
If it's running ok I don't see how you could hurt it more than it already is by riding it. Like the other guy said check out the oil filter. Take it apart and see if it trapped anything inside. Did you change the oil and look for metal specks?
i had a look at oil filter but didnt think to open it.looked ok oil looked fine aswell. can i take the top end off whilst engine is still in the bike .
you can take it off but its not much work to get the engine out...making it loads easier to work on. 2 brackets, one bolt, and the swing arm bolt. un plug the wires, and take off the carb and pipe. and shes out.:confused:
thanks for your help everyone shall be taking it to bits at the weekend
ok,couldnt wait till the weekend to strip my bike so did it today.engine is out cams look fine i think, only one is a little blue:confused: cillinder is like pitted like its got a arch shape on one side of the cillinder about centre, and 10mm wide to1mm at each end.can some one give me guidence as to what the process is now please i dont think i can get hold of a 330 bore kit in the uk . i know a place that rebores would they tell me what size rings to get or do i get them first not sure never done this. i have looked though most of the other posts to find stuff related [slandry] sorry if ive got your name wrong i know you have just done this can u help. :prof:
So you lucked out and your crank/rod and bearings are good??? And the cam bearing surfaces look ok???
how do i tell.thing is before i had taken the engine out. and kicked the bike up. smoke cleared after 10mins the engine sounded sweet but did lack some power.
That's the first thing I thought when he said the cam looked blue. I'd be looking REAL close at that!
It takes some pretty high temps to discolor metal. For one thing if the cam is blue you could have damaged the heat treating. Cam lobes are hardened so they can withstand the heavy loads from the valves/springs. It would have taken insane friction to generate that kind of heat to cause the discoloration. You know that screeching sound you mentioned? That's from insane friction. Maybe from the cam journals running dry. A good machinist can weld up and re machine the head if you're lucky. ????????????????????
So the cooling system was full during all this or was it as low on coolant as it was oil???????
To check the rod if you don't have dial indicators. Grab the rod and see if you can feel any play when you push down and pull up on it. If you can feel any slop your crank/rod is bad.
the cooling system was full.i have since learnt the cylinder connot be bored it has to be resleaved but you know that.erm i did push and pull on the rod and it did nt have any play .i have sent cylinder to get resleaved was wondering if i have to replace the piston . im having new rings but piston looks fine.thanks for your time
YES replace that piston please!
The OEM piston is not too expensive so it could be cheap insurance to replace it. You say the old one looks fine. If you checked it with a micrometer and it is within factory tolerances I can't think of any reason it couldn't be reused.
Mesure it like OldXl told. But I would put a new one in anyway.
thankyou to everyone who gave me the advise i needed.fixed cost me £260 in total. been told to do 500miles to run it in using semi synthetic oil.whilst i had the engine out i inspected bolts/bearings then i cannot get the rocker arm pivot shaft bolt out. its not a problem at the mo but would like to sort it anyway.i undid the nut and had to work on loosening the bolt moving it left to right until it turns all the way.but it wont come out.think the pivot shaft bolt is bent slightly in the middle anyone had this before?
I had that problem with a 94 KLX 250. The OD of the pivot bolt was the same as the swing arm pivot bolt. It was bent & I had to drive it out with a drift punch. Keep at it, you'll get it. Straighten it out, check the needle bearings.
  • Similar Content
    • By PigPenKLX450
      I bought my KLX in June of this year and this pic was taken earlyer this year I kept forgetting to post it. picture was taken in dove springs. to the left is jawbone cyn way down below and to the right is dove springs. I have gotten many many compliments on how good this photo came out I thought I would share it with all of you.
    • By STi21
      Well, here we go again.
      We had previously posted our Fork Conversion How-To here on ThumperTalk, hoping to help out anyone looking to upgrade their KLX140 or KLX140L by installing a set of KX85 or KX100 Forks. Our goal was to use 100% factory OE parts. No aftermarket anything. And we accomplished that goal. The Bike is drastically improved.
      But it just didn't seem complete. We wanted to finish the job with a new take-off rear KX100 Shock. Don't get me wrong, the KLX140L's rear Shock is actually pretty good. But it is a bit short on travel and refinement. So off we went to eBay to purchase a new take-off rear KX100 Shock. (For the record, the KX85 and KX100 rear Shocks are identical in every way.)
      We would be remiss not to credit art5, codious13 and a few others here on TT for their help and inspiration. A big thank you, guys.
      In order to make sure that anyone and everyone would be comfortable with this conversion, we took lots of pictures and measurements to help make this easy for folks to follow along.
      Here we have our KLX140L with the KX100 front Forks already installed per our previous post. (Eagle-eyed readers will notice that the Bike at this point has KLX140 14"/17" Wheels on it. We have since switched back to the KLX140L's 16"/19" Wheels.) Here we are, ready to go under the knife again:
      We removed the Seat, Plastics and Airbox, and then unbolted the rear Shock. Pictures are worth a thousand words, so here it is:
      Some interesting observations can be found when comparing the KLX140L Shock versus the KX100 Shock.
      First off, the KLX140L OE Spring rate is 5.0kg/mm and the KX100 OE Spring rate is 4.7kg/mm. We stuck with the softer KX100 OE Spring, but a heavier or more aggressive rider may want to re-use the KLX140L Spring.
      Second, the stock Spring pre-load on the KLX140L was measured to be about 80mm. The stock Spring pre-load on the KX100 was measured to be about 70mm. This is measured from the top of the Spring to the center of the top Shock mounting hole. (We ended up staying with the KLX140L's 80mm setting.)
      Third, KLX140L's Shock body is about 35mm longer than the KX100's Shock body. Here is where we find our additional three inches or so of suspension travel.
      Fourth, the KLX140L's Clevis is about 20mm longer than the KX100's Clevis. Not good. We did not want to drop the rear end of the Bike down, so we'll have to install the KLX140L's Clevis onto the KX100 Shock.
      Lastly, the KLX140L's External Reservoir is significantly shorter than the KX100's External Reservoir. Again, not good in this instance. As it stands, it is going to hit the KLX140L's Frame. More on this later:
      Using a Center Punch, Hammer and a Spanner Wrench, we loosened the threaded Spanner Lock Ring and Perch as far as they would go, and then removed the Springs from the Shocks. Nothing to it. Here is the KLX140L's Shock with the Spring removed:
      At this point we needed to switch out the KXL140's Clevis with the KX100's Clevis. The KLX140L's Clevis Bolt is pictured here:
      By simply putting a wrench on both the Clevis Bolt and the Clevis itself, we removed the Clevis from both Shocks:
      Now here was a potential concern. We did not know exactly how the Clevis' adjustment mechanism (AKA Clickers) is attached to the bottom of the Shock's center shaft. We have heard that the Shock can be damaged at this point, so we were very careful during this next step.
      It turns out (Pun intended) that there is a center rod that extends down into the Clevis in order to adjust the Shock's rebound dampening. If this center rod is allowed to slide out, and it did try to, the Shock may discharge and need servicing.
      That being said, just make sure that the center rod stays relatively static during the changeover. No worries here:
      And now we have a KX100 Shock complete with a KLX140L Clevis:
      Now, here things get a bit more interesting. How to get the KX100 Shock to fit into the KLX140L's Frame? Looking at the Frame's rear top Shock Mount, we can see that there is a threaded Collar welded to the Frame. This Collar has a 10mm ID, a 16mm OD and is 20mm long:
      We installed the KX100 Shock into the Bike, but did not install the top Shock Mount Bolt. Not surprisingly, there is a fair amount of bearing free-play in the Shock's lower UNI-TRAK suspension mechanism. Without putting any significant lateral pressure on the Shock, we tilted it to the left, and took some measurements:
      And then we tilted it to the right, and took some measurements:
      There was an easy 16mm of side-to-side play at the top of the Shock. Perfect. If we ground 8mm off the threaded Collar, the Shock should fit perfectly. After covering the Carburetor's intake with Tin Foil in order to keep any debris out, the careful use of an Angle Grinder and/or Dremel Tool was all that was needed. A bit of hand filing at the end is wise to ensure everything is just right:
      Obviously, we now had 8mm of space to the left of the Shock's top mount. What to do here without going aftermarket? Not a problem at all. We removed the two dust seals from the top of the now unused KLX140L Shock and slid out the center Collar. This Collar has a 10mm ID, a 16mm OD and is 19mm long. Again, perfect:
      Using a Dremel Tool, we cut the Collar in half. This way, if we goofed up and ground one of the halves a bit too short, we would have a backup:
      Using a Bench Grinder, we ground down one of the Collar halves to exactly 8mm:
      And finally, the moment of truth. We installed the KX100 Shock with our new 8mm matching Collar and torqued everything down per the specs in the Owner's Manual. The triangular UNI-TRAK Link at the base of the Shock was flipped over and ground down just a bit, as needed, per art5's recommendation. The flipped Link raises the rear of the Bike about one inch and stiffens up the rear suspension a bit. The Link is not visible in this picture, but you get the idea:
      Another view from the left side:
      This picture shows everything in it's place:
      And there you have it. So far, the Bike feels spectacular. Very smooth, very plush and very fun. And everything looks absolutely 'factory'. Awesome.
      Even though we only moved the top Shock mounting point 8mm to the right, well within the lower bearing's range of free-play, we will keep an eye on the bearings to make sure they are not wearing prematurely over the coming years. They are cheap to replace, if need be.
      It would be surprising if tilting the Shock over a mere 1.1458 Degrees will really have any negative impact. Again, no worries. Finally, here is the completed package:
      By the way, we are not trying to take credit here and pretend that we're the first people to put a KX100 Shock on a KLX140L. We're not. We just hope that this helps anyone out there, especially folks who might feel a bit intimidated by this process, to do the same thing if they would like to. It's really not that difficult. Have fun...
      Erik (and my now 14 year old son Tyler)
    • By v55
      Hi Everyone,
      Firstly, good morning. Let me introduce myself: I'm French and I live there. I think there is the better forum for technical issue in the world and would like to find a solution.
      Here is my problem:
      I have a '2009 KLXR, and the surface of the cylinder head which support camshaft (on the right side of the engine) where there is not bearing, is destroyed. Due to that there is a clearance between camshaft and head. I change two times cylinder head and still same issue!
      I'm disappointed! Does someone has the same problem? In your opinion it's due to what? And how to fix it?
      Apologise for my english!) If it is not clear i can join a pic.
      Thank you!
    • By Nick Gavrilis
      Hi everyone, here's my (rookie) dilemma. If you had 1000€ (1.293,551$) and no more, which one of these two bikes would you choose to buy and restore up to the point of being able to trail ride on the weekends? the 4T has 21.000 miles on it and the 2T has 12.000 miles (daily commuting is not an issue here, pure fun and learning how to cope with a dirt bike is, but on a tight budget ) Also any thoughts on reliability, cheap maintenance etc, would be appreciated or if someone has another bike to suggest that suits better for the job i would be more than happy to know about it. Thanx a lot!
      p.s. thumper talk rules!
    • By MostWanted117
      I have a cr85 and i have had it for a few years now. my uncle says that he wants me to get a more reliable bike. there have been a lot of options but I have narrowed down to the klx140l. I have been doing some research and found that the cr has about 10-15 more horsepower than the klx. this got me worried because I don't really want a bike that is any slower. I am sick of finishing the ride early because there is always something wrong with it. I don't know if I should keep the cr or get a more reliable bike and have longer rides.
      could people please give reasons why they think whatever they were thinking. don't just say things like " go the klx" or "the cr is way better".
      could people also bring up any other bikes that could be good ( don't want a cheap Chinese bike)
      I am 5'2 and weigh about 45-50kg ( 100-110 pounds)
      I do decent and long trail bike riding
