One Spark At Plug And Then None
99 XR400
440 kit, Hot Cam, Mikuni
Testing the ignition spark after changing out a stator as part of the electric start installation.
I have installed the CDI that came with the kit
I pulled the spark plug cap
Inserted a new Iridium plug
Held the plug to the cooling fins
Turned it over with the electric start
I get one spark and then nothing
Repeat and same result
Help and suggestions would be appreciated
Try a different plug.
get someone with a slight lack of brains to hold the plug against the head, probably with a pair of pliers.
that person was me
I donned a pair of leather gloves and held the plug cap to ground the plug to the cylinder fins
Sounds like the capacitors in the CDI have failed, borrow one of a mates if possible and try it.
(After trying a new plug.)
actually, do u still have the original CDI? if you do, try that. beats admitting to ur buds you've got bike problems.
