Adjusting valve.
I rode the bike for 3 years now. It needs some valve adjustement. it's the first time I'm going to do this, I've never opened a 4stroke before and I have no idea what to buy?
1-Do I need to buy new valves or can I adjust the existing one?
2-since im opening my engine, I was planning on buying
-New Valve wiseco or ProX ( 2intake, 2exhaust)
-New piston ring wiseco
-New Gasket (not sure about this one)
DO I need something else???
What you guys did?
Have fun riding:applause:
So, you are not doing a valve adjustment rather a valve replacement.
Buy RHC valves, do not lap them!!!
Buy OEM rings, light ball honing of the barrel
New head gasket, get a E model base gasket.
Why do you think you need to replace this stuff? How many miles on your bike, any problems? If you have low mileage, why not simply reshim?
I have about 5000 Mile on my bike, 90% off road. It does not start cold and the valve are pinking. after doing couple test with my buddy (good Mech guy) we have concluded that I should set my valve.
Reshim! Will I need to order those or do will they have it in stock at the dealer??
"setting your valves" is re-shimming... the "spacers"... your mechanical friend should understand this...
The shop will have shims, and a gauge... search for "valve adjustments" and it is probably on-line (here?)
If you'd like a confidence builder, Motopower has a DVD that shows you how to adjust the valves on your bike. Check out
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
