Difference between 01-02 300 exc and mxc
Can't find any specs regarding this, been looking for an exc and has to be a 02 at latest(green stickered here in calif) but see more of the mxc model. Will be using for tight singletrack, thanks
look in FAQ's. Exc has wide ratio gears and MXC close, EXC lights , mxc no lights. Just about the same other than that. 02 has better susp.
Are they 5 or 6 speed? Flywheels different? How about power, powerbands similar?
The MXC had a close ratio gearbox, like a motocross bike. They were intended to be geared high and used for desert races. You could just gear it down and use it for trail riding.
