yz125 wont start
08 YZ125 put it up,always drain fuel 2 days later went to ride wouldn't start
Has good spark,getting fuel etc. just won't fire.Any idea's before I take to a dealer to fix ?
How long has it been sitting? Try cleaning the carb and spraying out all the jets. Good luck and try and fix it yourself rather than the dealer, it's probably pretty simple.
getting fuel? to what the float bowl? the combustion chamber? spark plug wet? if not clean the carb.. remember takes 3 things for an engine to run.. fuel..spark.. compression..
How do you know it is getting spark?
Did you do the old take the plug out and stick it in the cap and kick it over trick?
If so, That's not sufficient evidence that it is getting "good" spark.
That just verifies that the pulse is getting to the spark plug.
A thin, weak or yellow spark out side of the combustion chamber doesn't mean that it is a strong enough spark to ignite the compressed mixture.
Have you tried a new plug?
Ride safe.
Ian
did you break it in rite?
bump start it and it HAS to start if it has gas, spark and compression/decent timing...if it runs good when you bump start it but wont idle, your pilot jet is clogged...dont take it to the shop...2 strokes are too easy to figure out...YOU CAN DO IT!!!! lol
Sat 2 days,took apart and cleaned carb
Thanks
All things done,this is why I'm baffled it has compression,spark and is getting gas.Even took carb off and put hand over manifold to make sure it was sucking
Yes,the kick and look at spark test.Have tried 3 new plugs
Yes kid has been racing for quite some time and all bikes have been broken in
Thanks
Tried that also no luck.This is the first time in a lot of years that I haven't been able to figure it out when a 2 stroke won't run.Even tried bypassing the kill switch just to make sure.This is bugging me as it has compression,fuel and spark
Maybe it's just really flooded. Try taking the plug off turning the bike upside down and turn the engine over so any excess fuel can drain out. You would be amazed how much fuel can end up in that bottom end.
