new 2007 klx300 need jetting help
Just got new klx300 need jetting advice what to use for main and pilot and clip position and fuel screw how many turns. Can a guy use kawi jets and needle to get good results or should I try dyno jet or something else. We run at 800ft for alt. thanks all your help is appreciated.
Kawi non-California parts will be an improvement but the DynoJet kit is even better and worth it.
Ride on
Brewster
+1 on the dyno jet kit- it also gives you a drill bit to drill the slide to make the carb respond faster.
dynojet. Pay a small price up front and end your misery down the road.
