neutral light
hi, can any one help, the switch at the engine is ok,the bulb and the wiring to the bulb is ok, so i was thinking that the relay is at fault ??:thumbsup: :thumbsup:
Are you checking this with a voltmeter? The stock cluster is LEDs, not bulbs, by the way. If you are checking for continuity with a voltmeter and are getting current in the wires going into the cluster (past the relay), then you're relay isn't to blame.
