Ohlins 48mxf Forks on 05 YZ250
I recently purchased a pair of 48mxf forks for my YZ and found the "mutter" is seized to the top cap assembly. The mutter is the suppose to move up and down to adjust preload.
Anyone hae these forks and run into a similar problem?
Anyone have these forks and have any feedback on them?
speak to your ohlins importer and get the best info first hand,should be great set up when finished,stock kybs pretty good on my 07 but earlier year forks had some issues but could be fixed also. good luck. phily cee
As per PM, same forks currently on mine, superb piece of kit and the best mod to date. Also have 49mm showa"A" kit forks waiting in the wings to go on. The Showa's will have to be something pretty special to earn there right to stay. Have you tried soaking the top cap in wd40 or equivalent. Mine turn quite freely with a spanner. You could try putting the cap back in the outer tube and clampingt them up in the yokes, then tap the spanner on the preload adjuster each way and see if you can free it. Manuals here,good luck and worth it in the end.
I think Stimps has 3 or 4 sets of the Ohlins forks. He collects forks like I collect silencers.
collect money you will be able to buy more stuff.
Anyone have a good thurough review on these forks? Or the shock, Ive got an 02 and who ever he had do the suspension destroyed it. About how much does it cost?
Don't be cheeky, I collect forks, shocks, pipes, silencers and plastics,,,and tanks come to think of it, and triple clamps and wheels and intakes and airboxes and subframes, I think that is the main extent of my perversion. More accurately anything YZ related cheap on E*ay. Only thing I don't collect is trophies....:thumbsup:
I started collecting e line pipe guards this week. The local shop had several sitting around for 20.00 each. Neat product, but I would be mad at 139.00.
The yz 250 is the perfect collectors bike. Fer changes and a lot of years to work with.
  • Similar Content
    • By Mikeybabbel
      Hey guys, I just picked up a running 03 yz125 a few weeks ago and upon tearing down the top end, I noticed the cylinder head looks a little beat up. Is it possible to just clean it up or am I better off just buying a new one? Thanks guys.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
