Tire change troubles
I replaced the rear tire and tube on my ttr 230.I installed the tube and whatnot and put the tire back on my bike and i hear tire leaking from the rim lock. What could this be? (P.S. The tire loses air sitting there but loses ALOT more when u ride on it).Im thinking a pinched tube? Oh yeah it also makes noise when you drive the bike andthe rim lock part of the tire is touching the ground. :thumbsup::ride:
it is VERY likely a pinched tube.
when changing your tires i find spraying the bead of the tire with WD40 works like a charm makes life alot easier but sounds like youve pinched your tube
You pinched your tube
