07 450ecx
I want to change it over to supermoto style. Not to race, just to ride to work and around town. Knobbies on the street suck. What size wheels do i need for the front and rear? what size tire can i fit on my bike? I dont want any tire rub for the rear.
Also what size are the axles on my bike front and rear?
Rims are best at 17in front and back. Front 3.5 wide, and either 4.25 or 5in wide, of which id go the 5. Your bike has 26mm axels. Not too sure about tires.
Anyone on the tire sizes?
120 front
150 for 4.25 160 for 5.00 rear
my opinion take rear 5.00 inch works peter and looking for excel rims is the stronger
I have just fitted the following to my 06 525 EXC.
(KTM Part Numbers)
58310050044 sprocket support x1 $130.19
54610459000 rubber dampers x6 $31.44
58413014000 Brake caliper carrier (320mm) x1 $103.94
58309060000 Front brake disc (320mm) x1 $169.76
5840900164430 Front wheel 3.5": x 17" x1 $499.00
5841000134430 Rear wheel 4.25"x 17" x1 $494.99
50033029014 14T front sprocket x1 $25.33
58310151040 40T Rear sprocket x1 $62.89
54810060200 Rear brake disc 220mm x1 $133.34
I fitted Michelin Pilot Powers
120/70-17 front $110.95
160/60-16 rear $132.99
Not an inexpensive exercise! But well worth the dosh as the bike is awesome for around town or freeway use.
It takes about 1 hour to convert back to off road use.
I have a complete set of plastics for off road so I can take all the lights etc off as a unit.
I also fitted an Acerbis "Cyclops"headlight unit which was an easy retro-fit and looks bad arse as well! ($110.00)
The only problem I have struck is locating the magnet for the speedo pick-up as there is no corresponding hole in the new disc.
Either drill one or epoxy it on. Take the smaller dirt rotor, lay it on the larger SM rotor and line up the mounting holes, then mark the larger rotor with a sharpie where the magnet mount hole is on the smaller rotor and drill! Make sure you have a hardened bit, those disk are really hard.
I can get the ktm hard parts as follows
complete front and rear wheel minus the tires. sproket and rotors for $900 brand new. silver or black
Sounds good, thanks for the tip
I fitted the dampened rear wheel to save long term gearbox wear
Sorry for the EPIC 5 year thread revival, but does anyone know where I can get the hard parts supermoto wheels with brakes [rotors] for $900 as stated above? I've been searching high and low, and I cannot come close to a deal like that.
Edited by mxrider14
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
