kx65 mods for 7 year old. mx and trail use???
My son has moved from a pw 50 to a crf50 to a ktm 50 senoir adventure and is ready for something more although the seat height a 25.6 s great and the auto transmision is nice too. He wants a kx65, I have read some threads stating the seat height can be lowered pretty easily and I figure a z start from rekluse will remidy the automatic part for now. I also read by putting a washer in the end of the exhaust it will restrict the power enough to make a smooth transition. Any other suggestions would be appreciated.
What I have not found is how to modify the bike slightly for trail use. We ride more than half of the time MX but also do a fair amount of trail riding... Any suggestions...
Thanks So Much!
T. Harte
P.s. as a side note if anyone is from the northeast, do you now if Ubridge MX park(in Uxbridge Mass.) is open and if so what's there schedule? Any other similar tracks near ct.???
you could get a fly wheel weight - that'll smooth out the power
not 100% sure they make one for the 65, but they should
and theres a track in CT called rocky hill, its near the ny border
My son is the same age and graduated from a CRF50 with a manual clutch.The transition in terms of the clutch and gears were no issue as he had been riding the Honda with a manual clutch since 5yrs old.The power of the RM65 was another story.The power and hit of the power band were frankly scary as hell:eek: .After jumping on it myself and experiencing it I simple didn't question his unwillingness to get on it.This being said, he is now enjoying the bike and these are the things that made a difference.First I slid the fork legs down as far as they could go.Next I installed Kuboda lowering links. The first session out, after a full rebuild this winter, a washer between the head and exhaust measuring 1.5" for the outside diameter and 3/4" for the inside were installed.It has made a huge difference in terms of illiminating the sudden and abrupt hit of the powerband which would be all but useless except, maybe on the track.
Further things to make this bike more trail friendly have been a glide plate and hand guards.I have included a few picks of the bike towards the end of the build.BrandonsNewRide008.jpg
I'll include current pics in a few days showing the links and other things that have been installed.I encourage and warn you not to let him on the bike until the washer is installed and he can reach the ground.The lack of a washer on the first ride out almost resulted in my son never wanting to get on the bike again.He is now producing big rooster tails :thumbsup: and having fun with it because he can feel the power coming on rather then a sudden explosion of power which would scare most riders; including myself and I have ridden almost everything imaginable since 7yrs of age.
Run a search. There is a thread about using a washer with a smaller ID between the pipe and cylinder. It will prevent the bike from coming on pipe. Once he gets used to it you can open the hole a bit more at a time.
Flyheel weight, lowering link and bar risers also.
wow, this is why I love this site! Thanks to all for the information and I will follow your advise pgbutler!
I am from the RI/Ma line. If i remember right, the track was closed. I may be wrong though. I used to ride that area frequently. Before they built the bike path, there used to be whooptee-doo's that went on for miles and brought you into RI. There are alot of trails off of that bike path. I moved to Florida about 7-8 months ago, so things could have changed.
  • Similar Content
    • By luke8500
      Hi all,
      I have a 2004 Kawasaki kx250 that died suddenly on me the other day. all i can get it to do is backfire every once in awhile. Tested the resistance and everything of the magneto and stator with a multi-meter and all is good.  Coil is new oem Kawasaki the reeds are brand new vforce and the top end and carb have been completely rebuilt.  key on crank is intact and all the timing marks are lined up. I hooked a timing light to it and spun the motor over really fast and found that it is sparking way to late.  The service manual says that it is supposed to fire 14 degrees before TDC but it is sparking way after TDC.  Im thinking its a fried CDI box since its the only thing i wasnt able to check.  Any help would be appreciated
    • By luke8500
      Hi all,
      I have a 2004 kx 250 2 stroke and it wont start.  it only backfires.  I was out riding it one day and came up to a stop so the bike was just idling and it started to try and die so i revved it up a few times then let it die and now it wont start back up.  It only pops or backfires when you kick it.  Its getting good spark and i just put a brand new plug and coil in it. I took the reeds apart and they look like they're brand new.  It was running great before so i dont know what happened.  Im thinking it could be a fuel problem even tho the plug is a little wet if you take it out after a bunch of kicking.  Any help would be greatly appreciated
    • By Zach121
      Alright, found three bikes all located where i live in Texas. I know they're all very different, but if you could tell me what you think each bike is worth, and which one would be the best deal. Thanks.
      Notes: Both 2 strokes have new top ends. I think the front brake lever is broken on the kawasaki.
      KX250 2002 $800-$1000?
      YZ125 2000 $1250
      KTM 400SX 2002 $1200
    • By Ryan Turner
      So I'm at a bit of a cross roads, I currently own a 06 rm250 and I love it. I also have a 02 kx250 which I'm selling with intent to buy a newer two stroke. I can't afford a newer ktm and the older ones aren't that great and kawasaki never impressed me. so I'm stuck between 06 yz250 and 05 cr250. I've heard the yz and rm after 06 are almost the same bike just the Suzuki handles better and the Yamaha has better suspension. So I'm not sure if I wanna buy carbon copy of my bike with slight differences. That's why I'm interested in a cr250 I heard the 02+ models RC valves are shit garbage but was mostly fixed in the 05-07 models. I ride at a track and at some bogs down the road from me. So from people who have owned both, what would you recommend. I know the cr is known for a hard hitting power band which I enjoy since im an aggressive rider. Should i just see which deal comes my way first.
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
