motor swap problems
I locked up the transmission in my old motor.
I bought a new bottom end off ebay.
I have everything back in my bike except the magnito/ starter stuff.
my new bottom end is from a kick start only model, and my starter gears, and
rotor will not fit on the crank shaft. is there a way to make this work or do i have to buy a new rotor, and make this bike kick start only??
nope,the left crank shaft half is different.
you would need a rotor,stator and stator cover from a kicker.
I believe you will need the starter clutch and stator rotor & cover off a kicker model for it to work. but you wont be able to use the starter:banghead: unless you change the crank half on the stator side to a E or S model crank thats alot of work:excuseme: hope you get it going soon good luck:thumbsup:
Hi Eddie, you beat to to it? Take Care
