Fcr MX help
I just installed my New Fcr From TT on my 2008 drz400 sm. The Bike Dies when you punch the throttle but runs good if you ease in to it. I set it up they way it said too. 160 main jet, 200 main air jet, EMN neddle clip 3, 45 pilot jet, and fuel screw 2 turns out
My elevation is 1580 feet. and I have a full yoshi RS2 and a 3x3 mod
Any Ideas?????
So if you take off from a stop it'll die if you try to accelerate too hard?
Does it die with a hard acceleration in all gears?
it will bog a bit if the RPM isnt high enough
Do you mean when you blip the throttle from idle w/ the clutch pulled in it dies, or after you actually get rolling? If it's the former, try turning the idle up just a pinch.
it will do it both ways
Did you check how long the accelerator pump is squirting for?
If it is too long it can cause a bog on acceleration.
How do i check it??
I will try the O ring mod tomorrow and see if that helps
did you remove the pilot air jet?
No. Was I suppose to?
there were some fcrmx carbs that needed the pilot air screw removed.im not sure if the problem had been fixed but i would remove it and try again
Yes, you need to remove it from the intake bell:
If this is an on going thing with the new FCR's from the TT store maybe it would be a good idea to include a note in the supplied instructions. :thumbsup:
the instructions could use several updates,however its been discussed at least 100 times here.
I do believe you meant pilot air jet :ride:
Neil. :thumbsup::rant::lol:
its fcr not frc :thumbsup:
yep,i ment pilot air jet.although you do need to unsrew it to get it out.my bad:worthy:
I removed the pilot air jet and did the O-ring mod.
the bike runs much better now but still not 100%
when I crack the throttle open In first or second gear it seems like theres about a half second delay till the power kicks in.
Also the exhaust Pops when down shifting. Is this ok or is my jetting off?
I was having similar problems, especially with the exhaust popping on deceleration under load. They say some popping is ok but mine was annoying. I went up one size on the pilot jet (47) and it solved all of my issues.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
